SL2500 Wiring in a Monitor 10B
saleenman
I won an action for some "mint condition" SL2500 Tweeters and I just would like to make sure that I don't screw up the wiring. The blown SL1000's had the Black wire plugged into the Red post and the White wire plugged into the Black post. The SL2500's are not color coded, but have one post larger. I assume that the larger post is the positive and that the black wire should be plugged into that. Correct?
Thanks!
Thanks!
Post edited by saleenman on
The SL2500 is not a replacement for the SL1000.Political Correctness'.........defined
