Acceptable Amp for SRS?
Bugstyvy
Bugstyvy Posts: 119
edited November 2012 in Vintage Speakers
Will My MC2300 Mcintosh be ok for the SDA-SRS? The whole common ground thing has me scared.
Mcintosh MC2300
Mcintosh 2105
Integra Pre amp 9.8
Pro-ject Record Player
Sony 200 disc CD Changer
Basic Wiring
60" Samsung Series 8
SDA-1.2TL
SDA-3.1TL (unused at the moment)
Post edited by Bugstyvy on
    F1nut Posts: 50,753
    Call McIntosh to check if your amp is common ground or not. Simple solution, eh?
  • Bugstyvy
    Bugstyvy Posts: 119
    might be easier to ask someone on here seeing Im sitting in front of the speakers and mcintosh is closed.
    Mcintosh MC2300
    Mcintosh 2105
    Integra Pre amp 9.8
    Basic Wiring
    SDA-1.2TL
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Hello Bugstyvy,
    In looking at the amp's schematic the left and right "com" connections are tied to the amp's ground. You'll be fine.
    Regards, Ken
  • Bugstyvy
    Bugstyvy Posts: 119
    Thank you!!!!
    Mcintosh MC2300
    Mcintosh 2105
    Integra Pre amp 9.8
    Basic Wiring
    SDA-1.2TL
  • [Deleted User]
    No problem, good listening!
  • motorstereo
    motorstereo Posts: 2,151
    A big Mcintosh amp and big polk speakers; I'm thinking you're going to love that combo.
  • Bugstyvy
    Bugstyvy Posts: 119
    was thinking of upgrading to the MC2500....
    Mcintosh MC2300
    Mcintosh 2105
    Integra Pre amp 9.8
    Basic Wiring
    SDA-1.2TL
  • motorstereo
    The 2300 is certainly no slouch. A couple of years back I was looking for a 2300 during my hunt for a great sounding and capable amp. Then I found a 2500 which just happened to be local (big plus with a 130lb amp) and honestly I couldn't be happier.
