Would a 2 x 300W Amp be too much for 10B's and/or RTA 11T's?
Bugstyvy
Bugstyvy Posts: 119
edited November 2012 in Vintage Speakers
I have a Mcintosh MC2300 and was wondering if that is too much power for these little guys?
Mcintosh MC2300
Mcintosh 2105
Integra Pre amp 9.8
Pro-ject Record Player
Sony 200 disc CD Changer
Basic Wiring
60" Samsung Series 8
SDA-1.2TL
SDA-3.1TL (unused at the moment)
Post edited by Bugstyvy on
    txcoastal1 Posts: 13,519
    Never 2 much if you already have it...just plenty of headroom
  • halo71
    halo71 Posts: 4,638
    They'll let you know when it's too much for them! Just don't get crazy with the volume knob and you'll be fine.
    --Gary--
  • skrol
    skrol Posts: 3,464
    Oh yeah, you'll know...
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Bugstyvy
    Bugstyvy Posts: 119
    The RTA's say 6 ohm? I can do 4 or 8 ohm on the amp. which do I choose?
    Mcintosh MC2300
    Mcintosh 2105
    Integra Pre amp 9.8
    Basic Wiring
    SDA-1.2TL
  • Bugstyvy
    Bugstyvy Posts: 119
    halo71 wrote: »
    Sorry cant seem to turn it down.......maybe the volume is stuck? :)
    Mcintosh MC2300
    Mcintosh 2105
    Integra Pre amp 9.8
    Basic Wiring
    SDA-1.2TL
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Too small of an amp will blow a tweeter, too big of amp blows something else, woofers, crossovers. If it doesn't sound right it's to loud.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Bugstyvy
    Bugstyvy Posts: 119
    Is the 6 ohm rating going to be a problem?
    Mcintosh MC2300
    Mcintosh 2105
    Integra Pre amp 9.8
    Basic Wiring
    SDA-1.2TL
    Bugstyvy wrote: »
    No not at all
  • Schurkey
    Schurkey Posts: 2,122
    Just like the throttle of a powerful car...you don't have to stuff the accelerator pedal ALL the way to the floor.
    "I" would set the amp to the 4-ohm setting. You'll have plenty of volts either way, the 4-ohm setting will assure that you have enough current.
  • drgalexo
    drgalexo Posts: 159
    Check on the back of your amp to see if you can change the input level. My MC7270 has a switch that allows changing the input sensitivity from 0.75v or 2.5v. It make help.
  • Bugstyvy
    Bugstyvy Posts: 119
    Input sensitivity is 0.5v non adjustable, can wire it to .25 ohms though!!
    Mcintosh MC2300
    Mcintosh 2105
    Integra Pre amp 9.8
    Basic Wiring
    SDA-1.2TL
