What are these worth?
breal74
breal74 Posts: 324
edited November 2012 in Speakers
I found these on the local Craigslist and would like to know what a fair price is, and are they wort it? I did a couple of searches, but found no info. Thanks for your help.
http://portland.craigslist.org/mlt/ele/3437056837.html
Post edited by breal74 on
  • skrol
    skrol Posts: 3,393
    A little sticky side of masking tape should pull those dust caps into place. Not sure the value but I am sure someone will pipe up soon.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • breal74
    breal74 Posts: 324
    The listing says they are the 3.1tl's. Where would you say they rank in the SDA SRS pecking order? I have been very interested in picking up a pair to head down the modification rabbit hole with and want to make sure I get a good pair.
  • gdb
    gdb Posts: 6,012
    Those are pretty rare/uncommon models, and I'd have no hesitation in paying the asking price, just so I could try them out. :wink:
  • PolkieMan
    PolkieMan Posts: 2,446
    That's a good deal.
    The old drivers are the best you can repair that dust cap easy enough.
    They are 3.1 TLS third from the largest. Tls can take the new rdo-198 upgrade
    and also you can update with the Gimpod Crossover boards. If they are close I would get them.
    FOR DOWNLOAD: The SDA Handbook. By Ray Smith
    http://vr3mods.com/LCSDAUpgrade.html
  • zingo
    zingo Posts: 11,258
  • wkjeffers
    wkjeffers Posts: 139
    I concur, I have seen these on ebay for that much or more. very rare.
