Klipsch RW-12d vs. Definitive Technology Powerfield 1800 (Need opinions)
Ethancf
Hi all,
I currently have a Klipsch RW-12d that I bought about 3 years ago used. My HT is a movie only environment. The only beef that I've had with the RW-12d is the port chuff with high volume and extremely low frequencies. Other than that, it's a great sub. I have an opportunity to purchase a used Definitive Technology Powerfield 1800 for about 3 bills. It appears to be all there cosmetically and the owner stated that there aren't any mechanical issues. I don't know much about this sub other than it has a 500 watt amp, an 18" driver, no auto on/off, and that it is an older sub. I'm assuming this would hit low frequencies nicely.
If you guys have any advice, I'd appreciate any input. Keep my Klipsch? Go with the DT? Any differences? I plan to audition it this week, but I thought I'd get some opinions.
Thanks,
Jason
Thanks,
Jason
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma
Post edited by Ethancf on
Well, I pulled the trigger on the Powerfield 1800! It is a BEAST and is in mint condition! Digs way deeper than the RW-12D...not that the RW-12D was a bad sub...just couldn't get low enough in movies.
Here's a photo!
Thanks,
Jason
THE SYSTEM
