Pioneer Vintage CS-99's
Gary Robertson
Gary Robertson Posts: 201
edited November 2003 in Speakers
I just got a totally free pair of the ol Pioneer vintage CS-99's with the 15 inch woof--they aren't anything like the current stuff but "NOT BAD". they have the wood grills with a lil' curtain behind them-- a neighbor gave them to me-he said that he bougt them back in 1975 with a bonus he got for joining the service.He also ghas a beautful Marantz receiver with about a million knobs on the front and pretty blue lights and fm dial up numbers--way cool. Does anybody out there have any knowledge of these old vintage models--i need to knoe how much wattage thwy can handle etc,etc.......
System #2
Yamaha cdc-755,(20 bit DAC )
Yamaha KX W382 cassette deck,
ADCOM GFA-545-II.ampfilier,,
ADCOM GFP-450 Preamp ,,BBE audio Restoration System (ARS)--Monster--M850I Innerconects and Monster 14 gauge speaker cable and the Fabulous POLK RT-7's with a Velodyne 12/15 subwoofer system ....she rocks.........
System #1:
Meridian 508-24 cd.(20 bit DAC)
Adcom -Gfp 750 preamp,
Bryston 14b-sst amplifier,
Martin Logan Prodigy Electrostatc speakers.and Acoustic Zen Silver Reference II innerconnects (rca) with Acoustic Zen Satori Shotgun speaker cable.
............................. "Jazz is democracy in music".
Post edited by Gary Robertson on
  • TroyD
    TroyD Posts: 13,124
    I've got a pair of CS-88a's....courtesy of George....
    The cabinets are to die for, they sound ok. Don't need a TON of juice to get 'em going. I run mine off a Marantz 2215 (15wpc) receiver. I'd bet that they will handle as much juice as you want to feed them. Probably only rated at 100wpc or so though. It should say on the back where the binding posts are.
    BDT
  • Tour2ma
    Tour2ma Posts: 10,177
    http://www.classic-audio.com/
    site has fairly extensive pioneer and marantz sections...
    More later,
    Tour...
    Vox Copuli
  • George Grand
    George Grand Posts: 12,258
    I wouldn't be surprised to find they can only handle about 40wpc rms. They don't have liquid-cooled dome drivers, and were designed for the low to mid power receivers of the day. Cabinets WERE their strong point. Quality of drivers installed wasn't.
    That Marantz receiver might be worth a bundle.
    George Grand (of the Jersey Grand's)
  • Gary Robertson
    I'm thinking about (just for fun) going to best buy or circuit city and getting some of those 200.00 --- 15 inch 4 ohm auto woofer and upgrade the tweets and mids..--Hell my Adcom amd Bryston can both drive 4 ohms like it was a feather. it might be distorted but the kids would dig it and the neighbors would cry--sounds like fun..ha,ha.s
    System #2
    System #1:
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Gary - nothing wrong with a Frankenspeaker experiment.
    Check out partsexpress and madisound, and find *better* drivers that would be a good (close) drop in match. Even pe's standard Dayton line would be upgrade to what Pioneer used in those models.
    If the drivers aren't labeled, I can probably find out what the network is expecting, and get you some basic parameters for your search.
    Cheers,
    Russ
  • gidrah
    gidrah Posts: 3,049
    I think the sesitivity falls in the low to mid 90s range. Here's a E-bay link for some CS-99A. The back says 100w.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3058168629&category=14993&sspagename=rvi:1:1
    If you Frankenspeaker, just be careful PLEASE! If you get tired of the components laying around taking up space and such, let me know.
    Make it Funky! :)
  • Jstas
    Jstas Posts: 14,970
    I'm going to rain on your parade here. Those "200.00 --- 15 inch 4 ohm auto woofer" are most likely subwoofers and not bass drivers like what is in your cabinets now. You can go and get them if you like but you will need hundreds of watts to drive a 15 inch sub woofer from a car application. You might want to run the speakers as bi-ampable because any car application mid-range/mid-bass or tweeter will not be able to handle the 200-400 watts needed to push that 15 inch sub. Well, you can get ones that will but you are pricing yourself way out of your plan.
    You can get component sets. They wll have a decent mid-range speaker and most-likely a dome tweeter of some sort. They will be expensive but should work OK in those enclosures. But if you are going to go with a "frankenspeaker" I think you would be better suited at finding an adequate set of drivers from one of the many companies that makes individual drivers for home applications. I have seen posts from quite a few DIY'ers here with references to companies that sell quality, inividual drivers. I think that would be a better route. After all, use teh right tool for the job and I don't think that automotive speakers are the right tool for the job you have in mind.
    Expert Moron Extraordinaire
  • ohskigod
    ohskigod Posts: 6,505
    might want to talk to the guys at www.audiokarma.org. if i am not mistaken, there are some fans of this speaker on that sight who will probably have all the insight you need.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • SDA SRS 1.2
    SDA SRS 1.2 Posts: 255
    Bought a pair of CS-99A's through eBay last year to replace the wife's old Pioneer speakers whose woofers' surrounds had rotted. They're rated at 80 wpc and 97dB efficiency and sound pretty good considering their age. Beautiful real wood cabinets and grills. A great den/study/bedroom pair of speakers.
    Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
    Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
    Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD! :) )
