Where to get short lengths of good spk cables?
kelley
kelley Posts: 287
edited November 2003 in Speakers
I run my 3.1's with 4 mono amps that reside next to the speakers. Currently I'm using Transparent cables but they are 8 foot lengths. Who custom makes lenghts in the 2-3' area?
SDS-400, SDA-1B, SVS 20-39pc+, B&K Ref 50, Denon 2900
Post edited by kelley on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    www.signalcable.com
    Tell Frank you are a Club Polk member for a small discount.
    Cheers,
    Russ
  • kelley
    kelley Posts: 287
    Thanks Russ, I emailed them.
    F1nut Posts: 51,786
    Kelly,
    Do to the nature of Transparent cables the 8 footer is the shortest length available for them to work properly. IMHO, you're better off with the Transparents than a shorter run of Signal. However, if you get the Signal's I'm curious to know what your results are.
