Polk CS2 Center Channel Upgrade?
Any thoughts on making this unit better or more compatible with SDA 2.3tls.
I have two MW6510's
Would two Monitor 4s be better?
I have two MW6510's
Post edited by PolkieMan on
The actual center channels that normally get recommended for matching vintage polks are the CS-350LS and the CS-400. The other alternative is to use a vintage polk.. preferably with the same tweeter. This is easier with non-TL's, cuz you can use any monitor 5, 7, or 10 with sl-2000's or RD0194's depending on what's in your fronts. Do you have RD0198's in you 2.3's? If so, you need to find a vintage polk that's upgradeable to the 198's too. I think sl-2500's are but not sure. I would think a monitor 4 would be a little small. A single RTA-15TL or 11TL would be badass, but you'd need the room. :biggrin:2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
This chart is from Polk Faqs page.
I'm sure many of you have already seen it.
Center Model
Matches With:
LSiC: No vintage matches.
CSiA6: SDA-SRS, SDA-1, SDA-2 (all versions), SDA-CRS, RTA-15, RTA-12, RTA-11, Monitor 5, Monitor 5jr, Monitor 7, Monitor 10 and Monitor 12, LS90, LS70, LS50, RT20p, RT16, RT12, RT10, RT3000p, RT2000p, RT2000i, RT1000p, RT1000i, RT800, RT800i, RT600, RT600i, RT55, RT55i, RT35, RT35i, AB855, AB805, AB800, AB755, AB705, AB700
CSiA4: RTA-8T, RT8, RT7, RT5, RT15, RT15i, RT25, RT25i, Mini Monitor, "Monitor", Monitor 6 satellite, Monitor 4
CS2: R30 R40 R50, S8, S6, RT400, M5
CS1: S4, R1, R2, RT3, R20, R15, R10, M3, M3ii, M2, M1Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
Thanks I have heard good things about the CS400 and CS400i looks like the CSiA6 is recommended and yea I have RDO 198s. Maybe a single CRS+ or a monitor 5 BTW it was going to use a pair of monitor 4s in series. I guess I can try different things like put the two MW6510 in the CS2 enclosure and order a Rdo-198 and figure out a crossover.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
I tried the two Monitor 4s in series, yuck :cheesygrin:POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
