Rinsing records
Mike Kozak
Mike Kozak Posts: 931
edited November 2012 in The Clubhouse
I have a bunch of record my dad gave me, some are very dusty, I have been rinsing them offwith water and they seem to sound great, am I doing any damage this way? I remember the old discleener system and used to have it but thought this might be a good alternative?
Post edited by Mike Kozak on
    txcoastal1 Posts: 13,341
  • thsmith
    thsmith Posts: 6,082
    Along as you are not getting the label wet but there are better ways to clean your records. If rinsing with water, distilled water would be better than tap.
  • strider
    strider Posts: 2,568
    Damage? Not really, I guess. The only concern I'd have is if you used tap water and let it dry on the surface, the flouride/chlorine/etc wouldn't do the record any good. If that's what you're doing to clean them I'd use distilled water.
    Not real sure how effective rinsing is, though. Better then nothing, I suppose, but if you picked up a dry brush like Mobile Fidelity's or a Hunt Carbon brush I think it would be much better at getting dust off.
    Wristwatch--->Crisco
  • dkg999
    dkg999 Posts: 5,647
    Or invest $80.00 in the Spin Clean record cleaner. Works Great as a way to get the major gunk off prior to using my VPI vacuum cleaner.
    DKG999
  • PolkieMan
    PolkieMan Posts: 2,446
    Yea I really works!
    I bought one of those Spin Clean record cleaners and I was amazed how such a simple appliance could clean my records. I was buying a lot of used records cleaning them at the sink with mild soap and soft sponge then drying them and finishing with a discwasher cleaner. I took those and cleaned them again with this device and got a lot of particles in the bottom of the tray and the record surface noise was a lot less.:razz:
