Do I need thicker wires?
SugarmillMan
I recently upgraded my rear and side surround speakers to 4 ohm Polk LSiFX. I have a dedicated high current NAD amplifier for these speakers.
Because these are 4 ohm speakers with a high current amp, do I need to upgrade my speaker wire from 14 gauge to a thicker gauge ? The total run is about 45 feet.
Fronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
Subwoofer: HSU VTK3-MK3
Electronics: Onkyo TX-NR 3010 receiver, Parasound Halo A31 amp, NAD T975 amp
Post edited by SugarmillMan on
Anaheim Hills CA,
HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Always, as heavy as you can be and also practical is good. If you have Dolby Digital for your movies, then your back speakers should be set at large because the complete frequency range is delivered to them when called for. If your back speakers are not full range (satellites) then they will not be getting the lower frequencies if you set up your amp right. The wiring should be sufficient with 14G either way. Surround speakers should be fine at 14G.Yamaha RX-V3000, 12 Band EQ per channel (x6)
SDA SRS 2.3 Non upgraded, 400w/ch
SDA II 3 Driver 2 Soft Dome 1 Passive 400w/ch
JBL 4311's 360w/ch
