Computer Guys Please Help!
daboyz
daboyz Posts: 5,207
edited November 2012 in The Clubhouse
My daughter has a couple year old Toshiba laptop. From what she says the cat walked on it and now the whole keyboard does not work. Is there something I'm missing that can be pushed or reset or do I need to take it in to get fixed? Iknow much more about audio than I do computers so any help would be appreciated.
Thanks, Dave
Post edited by daboyz on
  • Syndil
    Syndil Posts: 1,582
    Eh, I can't think of anything that would cause the keyboard to switch off. I'd say turn it off, remove the battery, reinstall battery, turn it back on and see if that helps. If it doesn't, either the cat broke the keyboard or knocked it loose from its connectors. If you're the handy type you remove/reattach the keyboard to see if that helps, and if it doesn't, you can buy a replacement keyboard from eBay and replace it yourself. Not terribly difficult if you're not scared of that sort of thing and a lot cheaper than having someone else do it.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    If not above works out is there any keys which looked stick down?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • BlueFox
    BlueFox Posts: 15,251
    Cats can create havoc with the random key pressing that occurs when they get on it. Mine screwed up my laptop more than once by walking/sleeping on the keyboard. Good luck.
  • gce
    gce Posts: 2,158
    Above the mouse pad is a small button that will turn IT off.. which, unless she was in a program, could make it appear she can't control the keyboard. Try that to see if mouse control returns?
    Hope this helps!
    Anaheim Hills CA,
  • unc2701
    unc2701 Posts: 3,587
    1)Plug in an external keyboard and see if it works; this will rule out any kind of software issue.
    2)Toshiba's of a certain vintage have a removable keyboard that attaches with a ribbon cable- hit google/youtube for instructions on how to get to it and make sure the cable is properly seated.
    3)The cat walking on it _probably_ didn't do this if it's not a stuck key like mentioned above. You might want to ask a follow up question or two. Unless the cat is SERIOUSLY obese. Just saying.
    Backburner:Krell KAV-300i
