Entry level turntable
usp1
usp1 Posts: 207
edited November 2012 in 2 Channel Audio
I am looking for a decent entry level turntable. A friend of mine has a collection of old jazz albums that he is willing to loan to me. The friend is a music lover but not an audiophile so the albums have been played on an old relatively beat up turntable. Any one have suggestions? I do not mind getting a used turntable but worry about shipping damage. I definitely do not want/need a usb turntable.
Post edited by usp1 on
  • cstmar01
    cstmar01 Posts: 4,424
    budget? Music Hall, Rega, Pro-ject can all be had around 500 and less if you buy used. Good entry level TT. Otherwise there are some older tables that could work and just depends on how far you want to go with it.
  • nspindel
    nspindel Posts: 5,343
    I'm quite happy with the vintage Thorens I have. TD166 MKII.
  • usp1
    usp1 Posts: 207
    Before I answer the budget question, let me ask if it is only the needle I risk or also the cartridge if the albums are not in great shape.
    At this stage I am looking for a real cheapo...maybe about $150 and maybe buy a better TT later once I have some more experience with it. Also, I understand that some the cheaper options have built in phono amps so that is a plus. I do have a rogue 88 with a phono input but I need to add tubes to that ...currently I use only the linestage.
    ANy suggestions on a good used table would be fine. (I live in a small town so not too many stores or craigslist options here)
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    where is local for you usp1?
  • gdb
    gdb Posts: 6,012
    Direct drive Pioneer off of ebay with a new stylus will serve nicely. If you want to escalate the sickness beyond that......there are plenty of avenues to explore afterwards. I'd also recommend an inexpensive record cleaning system, a lot of seemingly "worn" records are in reality, just really dirty. :wink:
    http://www.spincleanrecordwasher.com/
  • BlueFox
    BlueFox Posts: 15,251
    You might need to also buy a seperate phono-preamp, along with the associated cables. Not to many pieces of gear include that feature anymore.
  • gdb
    gdb Posts: 6,012
    gdb wrote: »
    A much better method than a USB TT for recording to digital files is:
    http://www.amazon.com/gp/product/B002GHBYZ0/ref=ox_sc_sfl_title_9?ie=UTF8&smid=ATVPDKIKX0DER
  • madmax
    madmax Posts: 12,434
    usp1 wrote: »
    Old scratchy LPs do not damage a needle unless there is a crack or a bunch of gunk in the grooves.
    Vinyl, the final frontier...
  • usp1
    usp1 Posts: 207
    TNHNDYMAN wrote: »
    Local is 61822 (east central illinois)
  • Msabot1
    Msabot1 Posts: 2,098
    What will damage a stylus? Lousy tonrarm,improper tracking weight,improper anti-skating,wrong tracking angle,filthy grooves,improper tonearm balance and last but not least,filthy lp grooves. If you are serious about getting into vinyl,get the best table you can afford.
  • nspindel
  • gdb
    gdb Posts: 6,012
    :eek: WOW, that'd be hard to beat !!! :eek:
  • usp1
    usp1 Posts: 207
    nspindel wrote: »
    Do I need a phono amp in addition to this turntable? It would otherwise be a good place to start at that price. THe reviews on amazon are quite positive.
  • chumlie
    chumlie Posts: 8,658
    Yes...Unless you have a phono in on your reciever.
  • usp1
    usp1 Posts: 207
    I have tube preamp with a phono but I need to buy tubes for the phono section. That will cost at least as much as a cheap phono preamp!
    SCompRacer Posts: 8,520
    usp1 wrote: »
    Here is an example of what can happen if the table isn't shipped in original packing. This from a seller that claimed they shipped turntables before. I even asked that the platter be removed. Fortunately I was fixing a table for a friend so I just needed the electronics inside.
    The other issue with used tables is speed control, or tonearm bearing issues. Older vintage direct drive tables might require cleaning of the speed control adjustment pots, or even more. Best to be able to test and try a used table before buying, unless you trust the seller.
    usp1 wrote: »
    Rogue has great gear. You have the integrated 88. 6DJ8's for the phono?
  • ViperZ
    ViperZ Posts: 2,046
    Dual 1228 or 1229 with a decent cartridge (Shure M97xE) will run you around 150. For another 50-80 you can pick up Cambridge Audio 540P phono and you'll have a great beginner setup.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • usp1
    usp1 Posts: 207
    SCompRacer wrote: »
    I have the Rogue 88 amp and the 66 magnum pre. Requires four 6dj8 for phono.
  • usp1
    usp1 Posts: 207
    How about a Dual CS2110...I saw one somewhere for $40...probably needs to work to get it back in proper working condition.
    The one in Urbana? Check out lpgear if you need a replacement stylus. If you could demo it before you buy it could be great for you. IIRC it is a belt drive and may need a belt. lpgear sells replacement belts as well.
    http://www.lpgear.com/
    I've dealt with Vintage Electronics for belts too.
    http://www.vintage-electronics.cc/
    Vinyl engine for info/manuals (need to be a member and log in to download).
    http://www.vinylengine.com/
    Audiokarma may have info on that table as well.
    http://www.audiokarma.org/
  • usp1
    usp1 Posts: 207
    Thanks for the info SCompracer.
