Test tone cd download info needed.
scottyboy76
scottyboy76 Posts: 2,905
edited November 2012 in The Clubhouse
I would like to download a test tone cd that has all the frequency ranges, im not very experienced in downloading, ripping, or using this kind of cd to check my speakers, so any info is helpful.
Travis(Tnhndyman), tried to do it for me when he was here, but we were having problems with a program on our computer at the time.
Even just recommending a website where i can learn more about using this kind of thing would be helpful.
I do own a spl meter so if i can get this downloaded and use it im good.
Thanks,
scott
humpty dumpty was pushed
Post edited by scottyboy76 on
  • thsmith
    thsmith Posts: 6,082
    I have a CD somewhere that came with my HSU sub. ARe you wanting to measure the full freq range or just subwoofer ranges? I could make you a copy, I do not know about downloading them.
    If you are doing full range you will need an SPL well suited for that. Radio shack meter will need some adjustments for subwoofer range and should not be used for full range.
    Have you looked at REW (Room EQ Wizard)?
    Manual measurements are slow and tidious.
  • scottyboy76
    See, i dont even know how I want to go about this, except i do want to check a full range.
    Not really worried about subwoofer range, as im gonna be checking speaks I know dont reach down that far.
    I appreciate the offer TH, but I think with my pitiable comp. skills, I think it would be Ideal to nab one from a site.
  • Amherst
    Amherst Posts: 695
    Here's a link for some downloadable tones with a few other various tests for your rig....maybe helpful for what you want to accomplish.
    http://www.audiocheck.net/soundtestsaudiotesttones_index.php
    Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
    Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
    Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU.
