cables, advice would be nice
seabeerob213
seabeerob213 Posts: 1,843
edited November 2012 in Electronics
whats the deal with these mediabridge cables they sell on amazon, i look and the get crazy good reviews in general, and are quite cheap, i know its not professional quality and nowhere near the best, but are they worth the trouble at all, for a small room and a very tight budget, anyone have any experience with them (at least with the sub cable), i know by any means it will be better than what i have now, three cheaprca cables spliced with male to male adapters,
i cant afford to pay the 50 euro that the local store wants for what appears to be a decent one,
Post edited by seabeerob213 on
  • PubFiction
    PubFiction Posts: 105
    They don't look that cheap, what about monoprice cables? Might be better if you have amazon prime and the one you want it eligible.
  • seabeerob213
    alright i will check those out
  • zingo
    zingo Posts: 11,258
    Monoprice HDMI cables are good, but I've never had a problem with Amphenol HDMI cables.
    http://www.cablesondemand.com/category/AVHDMI/URvars/Catalog/Library/InfoManage/HDMI_CABLES_(HIGH_SPEED_HDMI).htm
  • seabeerob213
    thanks, what are some good inexpensive wires, 14AWG stranded
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Bluejeans cables are a good starter value.
  • seabeerob213
    thank you
