A/V synch OPPO BPD-103
littlewoodboats
I have my new player installed and all seems well with the exception of an intermittent issue. The TV (Dishnetwork) Audio and Video will lose synch for no apparent reason. I am not seeing any patterns. It may be perfect all day then I will look over and notice the voices are out of synch. When I notice it happening I can continue to watch and it will get progressively worse. If I change channels up and then down the problem corrects itself and all seems well once again.
DVD's do not exhibit the problem.
I think this is most likely a dishnetwork problem. I installed the OPPO into the system with the dish receiver HDMI to the OPPO and from there to the display. I have it set so the audio is down sampled to two channel I send to the GFP-750.
I made it through almost 40 pages of discussion on the avs forum but did not see this issue discussed. Any other owners seeing this and how would one go about fixing the problem? Following the OPPO manual I think it is set correctly which makes me think it is a dish issue.
