fluid cooled speakers
leftwinger57
I've seen this term being used and for the life of me 1. I do not remember the brand and 2. what does it mean
and where is this so called fluid.Also what's it's purpose?
Are you referring to tweeters with ferrofluid?
You obviously have a computer. Do some research.If you can't hear a difference, don't waste your money.
:cheesygrin:
fer?ro?flu?id/ˈferōˌflo͞oid/
Noun: A fluid containing a magnetic suspension: "ferrofluid cooling"
http://www.google.com/#hl=en&tbo=d&sclient=psy-ab&q=what+is+ferrofluid&oq=what+ferrof&gs_l=hp.1.0.0i8l4.1246.9415.0.13139.11.11.0.0.0.2.2641.8302.3-1j6j1j1j1j0j1.11.0.les%3B..0.0...1c.1.nRCRGVhD2JU&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.&fp=d153103bd3c86bb&bpcl=37189454&biw=1440&bih=746
"In the case of speakers ferrofluids remove heat from the voice coils and help dampen the cone movement."--Gary--
