bass shakers one more time
dholmes
dholmes Posts: 1,136
edited November 2003 in Speakers
When I bought the plate amp , I forgot that when using the sub out from my pre-pro to the input of the amp, I will not have the use of the spk outputs, going to the bass shakers, now how do people use these sub plate amps going from sub in to spk output?thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Huh?
    You won't use the 'speaker outputs' (ie for speakers wired THROUGH the sub amp), you will use the 1 speaker output from the sub amp that is meant to power the woofer - which in YOUR case is the bass-shakers.
  • dholmes
    Thanks for tring to help, Im not the sharpest knife in the drawer! I figured out the plate amp you use the red & b,lack cord for the shakers & rca ins from sub out on pre-pro, NEED MORE CAFFINE!!! thanks again!!
  • scornful
    scornful Posts: 272
    Sounds like you had too much caffine to me.. lol
    Denon 3802
    B&K 7270
    Outlaw ICBM
    Behringer DSP1124P
    Samson S1000
    SVS 20-39CS+ (x2)
    RTi150's
    CSi40
    FXi30's
    RTi38's
    Win Vista HTPC
    InFocus 4805 ~100" Screen
