Which Receiver To Buy! Help
P.HUNT
P.HUNT Posts: 211
edited November 2003 in Electronics
i have 4 RT800i's and a C400i I had a Yamaha RXV-1200 and i am looking to upgrade to the RXV-2400 NOW FOR $900.00 is there anything better for the price if so why is it better. I WILL NOT PURCHASE THROUGH AN INTERNET STORE!! I am also in need of a rear center to match what would be a good choice
PROCESSOR-- Sherbourn PT-7010A
AMP
Sherbourn 7/2100A
DVD
DENON 3910
BLU RAY
PS-3
PROJECTOR --- Panasonic ae-900u
SPEAKERS
Klipsch Ultra2 System
92" Screen
PS Audio power cords
Buttkickers
  • organ
    organ Posts: 4,969
    If you like Yamaha, the 2400 should be an improvement over the one you have right now. Is there anything better? That depends...Each brand have their own unique sound. You should try to demo and read as many reviews of receivers to find the one you really want. When buying receivers, sometimes you're paying for features you'll never use. You should also check out Denon, Pioneer (Elite), etc. If you're willing to save a little more, Rotel and NAD make very good receivers.
    Maurice
