Accuphase E406 voltage conversion
cusco69
Hi,
Just ordered an E406 from USA and the voltage iso 120v. I have moved to Vietnam and supply here is 220v.
Need some help to see if I could change th? voltage from 120v to 220v for the amps. Thanks
Main: Accuphase E406 with Marantz CD6004 driving Polk LSi M705
Bedroom: Bose Wave
Study: Marantz KI PM Pearl Lite with PC driving Polk RTi A1 and DSW Pro 440
Bedroom: Bose Wave
Post edited by cusco69 on
Best to check with the manufacturer. Depending on the electronics packages used, it may or may not start smoking things.
Thanks rpf65. I heard and read somewhere that its possible but could not find the info yet. Will try harderMain: Accuphase E406 with Marantz CD6004 driving Polk LSi M705
Bedroom: Bose Wave
