rti10s from Polk-Direct on e-bay
sahmen
sahmen Posts: 39
edited November 2012 in Speakers
These are on e-bay for $549 a pair being sold by Polk! Would you consider that a good deal? I currently have a pair of more than 10 yr old rt55s as fronts which are still giving me first class performance. But I could move them to another room and replace them with the Rti10s as my main fronts if the upgrade in performance is worth the stated price. I need feed back on this soon before the e-bay units are sold off, in case I need to make a purchase. Any advice would be really helpful. By the way, I shall drive the rti10s with a Denon AVr991. Thanks.
  • Irrenhaus
    Irrenhaus Posts: 1,105
    edited October 2012
    sahmen wrote: »
    Hello:
    Don't know where you are located but Frys is selling the RTi12s for 599.00 a pair. But you will need a separate amp for sure.
    My 2 Cents.
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • sahmen
    sahmen Posts: 39
    edited October 2012
    I'm in Massachusetts, so I guess that means I miss out on this party. What a bummer! They also have pairs of the Lsi9s going for $419.99, and that is also something I could consider picking up were there a store nearby. Sigh! Thanks for your response though.
    Toolfan66 Posts: 18,399
    edited October 2012
    It's a deal...
  • chumlie
    chumlie Posts: 8,658
    edited October 2012
    Its a great deal. Be warned though. Power drops signifcantly on that Denon when you add speakers. Measured output 2 channels 129W, 5 channels 97W, 7 channels 81W.
  • sagasa
    sagasa Posts: 127
    Dont buy rti12 if you dont intend to use it with an amplifier. you will just be dissapointed.
    Front: Tekton Pendragon
    Center: Tekton Pendragon
    Surr.: Fxi5
    Umc1
    Xpr-2
    Xpa-3
    Xda-2
    Erc-3
    Xsp-1
    Vtf-2 Mk3 x 2
