MW6510 and MW6503
deronb1
deronb1 Posts: 5,021
edited October 2012 in DIY, Mods & Tweaks
I think these are the two nomenclatures for the drivers in my SDA 2Bs. What is the difference in the drivers?
    pitdogg2 Posts: 27,914
    edited October 2012
    2B's should have MW6511/MW6503 combo. SDA2a's used MW6510 x 2
  • deronb1
    edited October 2012
    Could be, I am not at home right now. Anyway, what are the differences in the drivers? Why did they use two different ones?
    edited October 2012
    they wanted to make an easier to drive speaker SDA2a=4ohm-sda2b=6ohm.
  • deronb1
    edited October 2012
    Gotcha, thanks for the info. Reason I am asking is that while I am having Trey do mods on my 2B boards, I was going to hook up my old RTA 8T crossovers to the 2Bs so I can still listen to them.
    edited October 2012
    that sounds sketchy since they used completely different drivers 8t= 6516 ....if it were me i wouldn't or your may need something new:)
  • deronb1
    edited October 2012
    The drivers in my 8Ts were the same as in the SDAs. They even had SDA stamped on them.
    F1nut Posts: 52,406
    edited October 2012
    Yeah, that's not going to work. The crossovers are not the same.
    edited October 2012
    deronb1 wrote: »
    Are you sure they are 8t? The RTA11t/15t used MW6510. I didn't think that 8t ever used mw6510 I've been wrong before and will be again
    I agree with Jesse If it were me i would not do it.
  • deronb1
    edited October 2012
    With the exception of the 6503, the drivers are the same as in the 8Ts. Why wouldn't it work? Because of the 6503s? I know it wont have the SDA effect, but it will do until I get the mods back.
  • deronb1
    edited October 2012
    Yes, they had two 6510s and an SL2000 in each speaker.
    F1nut Posts: 52,406
    edited October 2012
    deronb1 wrote: »
    The crossover circuits are completely different.
  • deronb1
    edited October 2012
    Still dont understand. The drivers can't tell what xover is driving them. It will be like listening to 8Ts but in a SDA 2B cabnet.
    F1nut Posts: 52,406
    edited October 2012
    Sure they can. The parameters of the crossovers and the drivers are designed for each other. Change those parameters and the sound changes for the worse.
    No, it will not.
  • deronb1
    edited October 2012
    No, it will not.
    But they are the SAME drivers. With the exception of the 6503, which was my original question.
    I'm gonna try it. will post
    edited October 2012
    MW 6503 1.820 5.24 N 3.550 E - 3N/M 6.540 Ohms 29 Hertz
    MW 6510 1.390 6.32 N 3.410 E - 3N/M 6.570 Ohms 31 Hertz
    MW 6511 1.405 4.34 N 3.496 E - 3N/M 3.130 Ohms 29 Hertz
    the 8t used the same ohm drivers. The 2b uses 1-4 and 1-8 ohm which come off two separate locations on the 2b XO that use the interconnect. one location off the 8t for both drivers
    I'm lost on the parallel or series here.
  • hewlew1
    hewlew1 Posts: 154
    edited October 2012
    Since you are determined to try this I would not push them very hard as damage to the drivers may result.
    F1nut Posts: 52,406
    edited October 2012
    No, they are not. The 2B uses one 6503 and one 6511, not to mention the difference in the parallel/series wiring.
    Will you get sound, yes. Will it sound just like listening to 8Ts but in a SDA 2B cabnet, hell no.
  • deronb1
    edited October 2012
    Well, just hooked it up with the new RDO-194s. Sounds good. I am using the wires from the 8T xovers. Just plug and play.
    The only caveot is the 6503 driver as opposed to a 6511. Based on the info in this thread, sounds like they are both 6 ohm.
