lsim 702 fx or lsif/x
jtshaw43
jtshaw43 Posts: 161
edited November 2012 in Speakers
Today i purchase polks lsim 706 cntr. I was thinking about buying the matching lsim 702 f/x (surrounds). I already have a pair of the lsi f/x(refurbs) that i purchased prior to deciding to go with the lsim series.would it be ok to run the lsi f/x with a lsim (707's,lsim 706,lsim 703') h.t. Set-up?or should i buy the lsim702's? Im posting this because im sure that someone in this forum has dealt with the same issue. Thanks for your input.....
  • Devlon
    Devlon Posts: 355
    edited October 2012
    I'm not clear on whether you already have some LSIM's for your fronts? I have the Lsif/x's and they are pretty awesome. But many, myself included, believe if it is at all possible match the components all the way around in a surround sound system. The surrounds are expensive, so maybe good advice is to use the Lsif/x's now until the funds become available to for the 702 f/x's.
    Living Room: HK AVR 354 as pre/pro, 2 x Polk Audio Micropro 4000, Adcom GFA-7500, 2 x Mirage OMD-15
    2 x Mirage OMD-5, 1 x Mirage OMD-C1, APC H15, Sony S790, Philips 52" LCD, Beogram 3000, FAT (Firestone Audio Tobby DAC), Harmony One
    Den: Sherwood R-972,as pre/pro, 2 x Velodyne SPL-1000R, 3 x Crown Drivecore XLS1500, 2 x Polk Audio Lsi9
    1 x Polk Audio Lsic, 2 x Polk Audio Lsifx, Sony S790, APC H15, Dspeaker Dual Core 2.0, W4S DAC 2, Keces DA-151
  • jtshaw43
    jtshaw43 Posts: 161
    edited October 2012
    Thanks. Im thinking about using them if i can,for 11.2 (with ext. Amp) for 11.2. If that wont work, i can always sell them on e bay. P.s. Im in the process of buying the 707's.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2012
    Did you buy that 706 in Wisconsin for $600 off eBay?
  • jtshaw43
    jtshaw43 Posts: 161
    edited October 2012
    Yes??
  • falconcry72
    falconcry72 Posts: 3,580
    edited October 2012
    leroyjr1 wrote: »
    I was watchin that one...
  • leroyjr1
    edited October 2012
    Was only a couple miles from me.
  • falconcry72
    edited October 2012
    jtshaw43 wrote: »
    So, what are the other speakers in this 11 channel setup? You mentioned the 706, 707's, and 703's, so this pair (either the FX's of 702's) would make (7) channels. What are the other (4) channels? My thought is this: if you can afford (9) channels of LSiM's, you can afford (2) more. You'll be glad you did.
    I'm somewhat of a purist, so if you can't afford (11) channels of LSiM, I'd say do (9) of LSiM, and leave the LSi's out of it... or do (7), or (5), whatever works with your budget.
    That said, I am running LSiFX's with LSiM fronts because I won't spend the money for the 702's... yet, and it sounds pretty good. :smile: I am also using an original LSi for a center. I'd prefer an LSiM center and surrounds, but I won't swing it right now. I may even sell the 703's I'm using as fronts and go back to LSi9's as fronts to save some money. Not because the LSiM's aren't awesome, just because I have a good 2 channel rig already, and I only use the HT rig for TV and an occasional movie, so I feel like the LSiM's are wasted in that setup.
  • jtshaw43
    jtshaw43 Posts: 161
    I just purchased a pair of 707's to go with my 706 cntr. I don't know which ones to get next. Probably two pair of lsim 702's (one pair for rear surr./ another for front effects). I also plan on buying another pair of 707's for rear effect speakers . But to be honest , i'm still not sure.
