71 pound amp... Particle board furniture. GO!
kuntasensei
kuntasensei Posts: 3,263
edited October 2012 in The Clubhouse
So I have a Parasound HCA-1206 arriving in the next few hours. Unfortunately, there is nowhere for me to put it except on top of a cheapo armoire made out of particle board. I used to have a 29 pound receiver on it before, but... 71 pounds is a whole other monster. So here's the question, folks: What's the best way to shore up the top of this thing? I was thinking a 1"x2" under the cabinet top, screwed through the sides of the cabinet, would give it enough strength not to bow, but I could be wrong.
My only other alternative, it seems, is to put it on top of my equipment stand and get a center channel stand to put in front of that. Any ideas would be appreciated!
See pics for what I'm working with here. The place I'm putting it is where the Belkin PF60 is in the pics (left armoire).
Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Post edited by kuntasensei on
  • SolidSqual
    SolidSqual Posts: 5,218
    edited October 2012
    I like these as a nice alternative to wood: http://www.soundocity.com/Soundocity%20Component%20Stands.html
    I know you are looking for reinforcement of the existing particle board piece, but maybe you should just call it quits.
    EndersShadow Posts: 17,596
    edited October 2012
    Honestly I would look into building yourself a Flexy DIY rack. Easy to do, totally customizable and not too expensive depending on the parts you use.
    You could use really thick shelves that will hold everything.
  • codyc1ark
    codyc1ark Posts: 2,532
    edited October 2012
    Meh, I think your worrying too much. I think it'll hold it just fine. Can you sit on it? :cheesygrin: Try to sit on it, assuming you weigh more than the amp, you'll be fine.
    edited October 2012
    codyc1ark wrote: »
    This just sounds like the start of a PFB thread.... So to test if the cabinet would hold the amp I decided to sit on it and.......
  • dkg999
    dkg999 Posts: 5,647
    edited October 2012
    I would screw a 3/4" piece of plywood to the top, either on top or below the current top. The alternating grain of the layers of plywood actually gives it less flex under load than a 1x4 piece of pine. Use lots of screws, glue if you don't care about recovering the original state of the piece.
    DKG999
  • kuntasensei
    edited October 2012
    Unfortunately, I'm stuck with the stupid armoires. Can't ditch 'em. And that sucks, 'cause if it were up to me, I would have put a VTI stand across that whole front wall and had my screen on the wall instead of free-hanging. So I'm forced to try to shoehorn this amp into the existing furniture until I buy another house (at which point I plan to have a dedicated room, so no worries). Also don't really want a standalone amp stand out in the middle of everything, for evil pet reasons. (See my past stories about the dog using my RTi70 as a fire hydrant and Polk kindly sending me a new baseplate.)
    The plywood thing may be a good plan. I was thinking more of 1"x2" cross-members underneath, but that's worth a look. Either would be hidden by the cabinet doors.
    Of course, I may just unpack it, set it in place and see if the damn thing bows. I'm just trying to get some options, 'cause I really want to hook it up tonight! :cheesygrin:
    Equipment list:
    Emotiva XPA-3 amp
  • chumlie
    chumlie Posts: 8,658
    edited October 2012
    While i don't agree with his testing method, i think Cody's correct. Or just use the plywood on top. Wouldn't bother with the screws.
  • BlueFox
    BlueFox Posts: 15,251
    edited October 2012
    ....hold the amp in your lap.
  • kuntasensei
    edited October 2012
    I bought two Parasound amps in the last two weeks... I'm not about to go to the doctor over it, guys! :lol:
    Equipment list:
    Emotiva XPA-3 amp
  • nwohlford
    nwohlford Posts: 700
    edited October 2012
    It is hard to tell from the picture, but some of these old units were built to handle the old, large CRT TVs, so 70lbs would be nothing. I have my 110lbs amp on something that looks pretty cheap, but it was meant to hold that weight with the 30"+ CRTs.
  • gdb
    gdb Posts: 6,012
    edited October 2012
    Put it on.......if it sags, take it off, then reinforce. Simple.
  • obieone
    obieone Posts: 5,077
    edited October 2012
    "Hold my beer a second, I wanna try something...":razz:
  • kuntasensei
    edited October 2012
    nwohlford wrote: »
    Actually, the two armoires used to be the sides of a single entertainment center with the middle part holding a 27" tube TV (which I removed to put that Sanus stand in between them). So maybe I'm being overly concerned. Good call on that. Hadn't considered it.
    As I was typing this message, UPS showed up with the amp. Pulled it out of the box, set it in place... Shelf seems fine. It's a little too deep for the shelf, but I popped the thin back piece out and pushed it back with no worries. Looks weird there... but should be just fine for now. Over time, I could definitely see it bowing though. May throw a 1"x2" under there just as a precaution.
    And now, I grab a handful of old junk RCA cables to hook it up until I order some ICs from BJC. :cheesygrin:
    Equipment list:
    Emotiva XPA-3 amp
  • decal
    decal Posts: 3,205
    edited October 2012
    You gave up a lot of strength of the unit by popping out the back, no matter how flimsy it seems to be.
  • kuntasensei
    edited October 2012
    No no... the back was seriously a piece of 1/8" flexible MDF that just sits in the back in narrow channels. It has no structural value whatsoever. If it were the back UNDERNEATH the cabinet top, I would agree.
    The good news is that the thing fits. The bad news is that one of the channels is very obviously bad on the amp, and I tried swapping cables, running different speakers on it, etc. :cry: Contacted the seller by PM.
    Equipment list:
    Emotiva XPA-3 amp
  • ken brydson
    ken brydson Posts: 8,787
    edited October 2012
    obieone wrote: »
    That made me laugh. Not sure why...:cheesygrin:
  • gdb
    gdb Posts: 6,012
    edited October 2012
    You might be a redneck ! Sorry, couldn't resist.:cheesygrin:
