LSi15 woofer out of phase
So, I just realized something.
As I'm looking at the schematics of the LSi15, the woofer is out of phase (+ and - are "reversed"). I'm sure this is a design feature, but it seems really strange to me.
Has anyone tried reversing the polarity on the woofer to get bigger bass from it? And how has that worked out? I don't really want to be the guinea pig here.
Anyone? Thanks.
Monty
Anyone? Thanks.
Monty
Do you believe Polk intentionally wired to woofer out of phase to give you less bass?
Certain crossover topologies require a driver(or drivers) to be wired out of phase for flat response at x-over points, otherwise there would be a peak or null at the crossover point."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Ha, well, good question. Probably not. I'm not a speaker designer, so I really have no clue. It seemed strange, that's all. I'll quit worrying about it.
Is there a reason your wanting more bass from the lsi's ? What are you driving them with now ? Do you have a sub in the mix and if so what are they crossed over at ?HT SYSTEM-
lsi 9's -
You guys are too cool. I think I had the same problem 99% of lsi15 owners have. Power.
I've gone from a POS Sony receiver, to a Rotel 100x5 amp, to an Outlaw 7500, to a bi-amped setup (with custom crossovers), to finally, now, a pair of Emotiva XPA-1 monoblocks (500W 8ohms, 1kw 4ohm). FINALLY. Finally, the bass is great. LSi15s are, as has been said a million times, just a humungous load for an amp.
