New Speakers mabey
C Bennett
C Bennett Posts: 24
edited November 2003 in Speakers
Thinking about new speakers just not sure if I want to do it yet or just stick with what I have. I was not wanting to spend more than $200 on a set of fronts(left and right) and then later(after more money is saved :) )the center. I have been researching a little and have been looking at Wharfedale Diamond 8.1's,Polk RTi28's,CSW(dont know the model # off hand). Anyhting you can tell me about speakers in this price range and for a good set at a cheap price what I should be looking at. I don't know if I really need new ones though as my S4's are in PERFECT shape. I just don't know how they are compared to "todays speakers" or if I am missing something that I could get in a more modern speaker for $200 or under? Like I said I may not really need anythign and the S4's may actually be just as good as say the RTi28's or the Diamond 8.1's but I really don't know. I dont want to spend more money just to spend it id just as soon keep the S4's(for $200 or less). But if any of these(or ones you guys know about that I may not)would be a lot better than the S4's I'd consider it. I use them mainly for HT use and not a lot of music.
