Optoma HD20 1080P Projector & 100in Fixed Screen $650
KASR
KASR Posts: 450
edited October 2012 in For Sale (FS) Classifieds
Well, I've moved and it's with a heavy heart that I announce that my new place doesn't have a room or wall that can accommodate my HT setup....but my downsize is your gain because I'm letting one of you lucky SOB's scoop up my babied gear and enjoy home theater as it was meant to be: 1080P @ 100 inches! (let's be clear that I am keeping my Polk gear - no way am I getting rid of my sound!0
(and yes.....there were tears.)
and
for $650 shipped anywhere in the U.S.
If you're thinking "man, that's a great deal!" ... well, it's because it is.
PM me and let's get it over with so I can begin the grieving process! ;)
Optoma HD20 ( new bulb, less than 80 hours on bulb)
  • 1,700 ANSI lumens
  • Native 1080p (1920 x 1080) resolution
  • 4000:1 contrast ratio
  • Max lamp life: 4,000/3,000 hours (STD/bright)
  • Features DLP? & BrilliantColor? technologies by Texas Instruments?
  • 2 HDMI?, VGA in, component video, composite video & +12V trigger
  • Dim: 3.82"H x 12.76"W x 9.21"D
  • Weight: 6.4 lbs
ELITE SCREENS ER100WH1 Sable Frame Series Fixed Frame Screen
  • 100"
  • 49" x 87"
  • 16:9 HDTV format
  • CineWhite
  • 1.1 gain
  • Non-reflective black backed screen material eliminates light penetration
  • Black velvet covers aluminum frame & enhances overall appearance
  • Screen material provides flat-tensioned uniformity
  • Easy to assemble
  • Installs in minutes
  • Adjustable fix plates provide equal tension over the entire projection surface
  • Sliding wall mounts are horizontally adjustable
Post edited by KASR on
