new (vintage) 2 ch. bedroom system.
soundfreak1
soundfreak1 Posts: 3,414
edited October 2012 in 2 Channel Audio
Parasound hca 800ll (being gone thur and cleaned, set up and tested by my tech.) will be hooked up to my adcom SLC505 passive pre, druving my polk (fully modded) 5jr+ speakers. Still cinsiderung the cd player and DAC. Should make a nice bedroom system. Thoughts??
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • soundfreak1
    edited October 2012
    WOW not even a "Woulda, couda or shoulda!
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • ambiophonics
    ambiophonics Posts: 727
    edited October 2012
    You may need to give folks more than an hour to respond - be patient I'm sure someone will chime in.
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • Conradicles
    Conradicles Posts: 6,376
    edited October 2012
    Maybe add a small sub. Looks good to me.
    edited October 2012
    That looks like a nice setup up, as Con. says above, it may be a little bass shy. I run full size 5As in a room that's 17' x 10' x 8.5' and the bass is "adequate" only!
    What's the budget for CD/DAC? If it's tight, you might want to think about a CDP that also has DAC access (coax/toslink inputs), there are a number on the market that let you use the CDPs DACs if they are good enough?
    I have a ton of vintage gear but the bedroom is SMALL (how big is yours?) so I just run a 2.1 Onkyo AVR Polk Rti-4 system in there; which is fine for my purposes. A small 8" 100 watt RMS sub picks up the low end nicely. But I use that mainly for DVDs and Blu-rays with the HDTV.
    But you have some higher level gear there!
    Have fun!
    cnh
  • soundfreak1
    edited October 2012
    The 5jr+'s really dont need the help in the base since the recap was proformed, however this systen will not be used for "critical" listening, just background and evening listening in bed and in the morning getting ready for work and with the vido monitor in the slc505 may connect to the bedroom tv.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    edited October 2012
    As far as DAC goes thinking of just letting the yammy and the adcom 700 pull double duty as the racks are side by side with my main sys. Listed below. Or if too lazy to keep switching rca's back and forth might just get a decent cdp with a fairly good built in DAC. Just dont know of one to fit the bill, agaun as for the intended use the cd isnt critical but..... U know how yhat goes. LOL i think the system is over and above for its intended use but again ..... No half measures at l
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    edited October 2012
    Hit the post bottom by accident... " no half measures as i always intend than i go overboard. LOL
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • kappclark
    kappclark Posts: 136
    edited October 2012
    I have the HCA 500 and love it !
    ** Bill Clark Windham, VT **
  • soundfreak1
    edited October 2012
    Get to pick up the HCA 800ll this afternoon. Tech is all done, all cleaned, bias set, outputs balanced, everything gone thru and ready to go! I think it will be nice for a small bedroom system.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    Toolfan66 Posts: 18,183
    edited October 2012
    Would of
    Could of
    Should of.........
  • trav0810
    trav0810 Posts: 1,056
    edited October 2012
    Beats my bedroom system. I am running nothing more than a pair of RTi8's off of a HK stereo receiver. I have that hooked up to the HD DVR and listen to the music stations of a morning as I am getting ready for the day.
    The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
    Sony Playstation 3 for CD and Streaming
    Thorens TD320
    Modified Carver C-1
    Carver TFM 42 and 45 Amplifiers
    Polk RTA15TL Speakers w/Decato mods
    White Lightning Moonshine DIY Speaker Cables and Interconnects
  • soundfreak1
    edited October 2012
    I guess i asked for that. toolfan! LOL
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    edited October 2012
    Just hooked up the parasound. First impreasions....not bad.....nor bad at all. Sounds better with the adcom pre in bypass though. May go back to a passive volume attenuator, or upgrade the volume pot in the adcom. Nice detail on the warmish side but very open sound stage.deff. need to go to 194's in the 5jr's though it really shows the sl2000's to be a little edgie.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    edited October 2012
    Damn once this 800ll warms up! Holy crap its a lot nicer than i expected. Great base ( more and tighter than i was expecting) prob. due to the cap up grade (clarity sa caps ) i mean it not as dynamic as the 1200 with the 12c's but damn nice. I really like parasound amps, they seem to work nicely with the polk sound. Any one know of a componet A/B switch for my cd and DAC so i don have to keep changing the cables. Sounds so good i would like to keep it doing double duty with my main system( they set right next to each other in matching bello stands?)
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
