Explanation of bridging amps
snake1
snake1 Posts: 567
edited October 2012 in Electronics
I basically know what bridging does but now that I look a the back of an actual 2ch that can do it, I'm not sure how to hook it up. I'm attaching a pic of one so that if someone can explain, then they can use something I can see (visual learner).
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
Post edited by snake1 on
  • BlueFox
    BlueFox Posts: 15,250
    edited October 2012
    From the manual, page 6
    Mono Input and Speaker Connections
    1. Turn the unit off and remove the AC cord.
    2. Connect the single cable from the preamp or controller to the R channel Input jack.
    3. Set the Bridging switch to its Mono position.
    4. Connect the positive lead of the speaker wire to the red R + channel speaker pair A terminal.
    5. Connect the negative lead of the speaker wire to the red L + channel speaker pair A terminal.
    6. Do not connect anything to either the L - or R - speaker terminals.
    7. If you have a second mono speaker repeat steps 4 - 6 with the speaker pair B terminals
    8. Reconnect the AC cord.
    http://www.parasound.com/pdfs/OWNER_GUIDE_2125.pdf
    Google is your friend.
  • snake1
    snake1 Posts: 567
    edited October 2012
    I read that very thing, but still wrapping my head around it. Humor me here. To bridge this particular amp for its 400 rated watts, you just hook it up as this states and hook it to one speaker? The other speaker pair will be empty? If i want another 400w to the other speaker, I would get another identical amp, run the same instructions but this time hook it to the L channel input? I know I'm probably asking the same thing over and over but it helps me understand.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
    F1nut Posts: 52,298
    edited October 2012
    Correct. You basically end up with two mono blocks. However, bridging isn't all it may seem to be. You actually lose a bit of headroom, generally have higher distortion levels and only gain a few dB in SPL. You're better off getting one good stereo amp or two actual mono blocks.
    heiney9 Posts: 25,630
    edited October 2012
    ^^ +1
  • stretchl
    stretchl Posts: 1,334
    edited October 2012
    Question -
    Is "bridging" the same thing as "bi-amping?"
    - Isaac Asimov
    Hi-Fi
    Cabling by Groneberg
    Visuals
    edited October 2012
    stretchl wrote: »
    Question -
    No....
    Bridging is taking a 2 channel amp for example and making it a one channel amp at almost double the power.
    Bi-amping is taking 2 amps, and connecting to one speaker by way of an external crossover. Some variations of this exists but one is to use a 2 channel amp per speaker connecting each channel to the top and bottom posts of the speaker.
  • snake1
    snake1 Posts: 567
    edited October 2012
    Thanks for the explanation fellas!!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • snake1
    snake1 Posts: 567
    edited October 2012
    Is this an 'across the board' problem or just with ones you've personally heard?
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • stretchl
    edited October 2012
    tonyb wrote: »
    No....
    OK... I just gotta spend some time getting my head around this...
    - Isaac Asimov
    Hi-Fi
    Visuals
  • nhhiep
    nhhiep Posts: 877
    edited October 2012
    snake1 wrote: »
    it depends on how they designed the amp. I know all of my HK Citation 7.1 amps sound as good as bridge mode. In fact, they designed it with bridging in mind according to the manual, resulting in the THD stays the same .003 from 20-20khz, but with more current when bridged.
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2012
    I have heard amps designed with Bridging in mind and while they do sound better than other amps bridged they still loose a bit of headroom. The nuance from silence to loud is smeared a bit in bridged mode.
    I only bridge amps for subwoofer use. I have tried several amps in bridged mode full range and never felt the added watts were worth the trade off in quality of sound. Citation included as well as Rotel, Parasound and B&K. They sound better as they are intended, not bridged.
    edited October 2012
    nhhiep wrote: »
    resulting in the THD stays the same .003 from 20-20khz,.
    That right there tells you absolutely nothing about how an amp will sound, so just because they were able to measure the same (in bridged and stereo) means absolutely nothing.
