Outlaw 2150
bwest1000
bwest1000 Posts: 19
edited October 2012 in Speakers
After reading through all of these threads, it is making me concerned that my outlaw 2150 is under powering my LSi25s. Is this just an idle worry? Am I just worried because I am always wanting an excuse to upgrade? I like to listen to all kinds of music, and I sometimes like to listen loud. Outlaw gets warm but never hot. Any thoughts? Ideas? Reassurances?
Post edited by bwest1000 on
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2012
    If it works for you and sounds fine great. Can your speakers sound even better with more power, absolutely. The good news is that the 2150 does have preouts for separate amplification whenever you decide you want to hear what your speakers are really capable of.
  • codyc1ark
    codyc1ark Posts: 2,538
    edited October 2012
    cfrizz wrote: »
    Great advice here. +1
  • sponger
    sponger Posts: 325
    edited October 2012
    Multi-channel receivers are notorious for having overrated power output, but I'm not sure if that applies to stereo receivers. Being as that stereo receivers are about the same size as multi-channel receivers and yet have only 2 channels instead of 5 or 7, I'd expect there to be more power output per channel. Plus, multi-channel receivers have a lot more functionality, and so that's even less space going towards the engine bay.
    Like the others have said, it generally never hurts to have more power available. But, IMO, if the Outlaw 2150 does what the manufacturer says it will do, then you're not in too bad of a spot.
    You mentioned that it gets "warm." Are you concerned about its 4 ohm stability?
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
