How to Insert Picture in Text?
mufsoman
mufsoman Posts: 640
edited November 2012 in Forum Testing Area
How can I insert a picture in a specific part of text in a post? I've seen it in other posts, but cannot figure out how to do this. Please help!!!!
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime Pinnacle towers, Ultra center channel and Prime bookshelfs (side surrounds)
Atmos: Polk OWM3 x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
Post edited by mufsoman on
  • 11tsteve
    11tsteve Posts: 1,166
    edited October 2012
    use the photo tool in the editor to put the pic in your message, and then cut & paste it where you want.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • mufsoman
    mufsoman Posts: 640
    edited October 2012
    What's the "photo tool in the editor"? Do you mean the "Manage Attachments"? If different, then where/what is the photo tool editor in the Polk forum?
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
  • 11tsteve
    edited October 2012
    this here....
    it will place attach code into your message, and you can cut and pasted beginning/ending tags wherever you like.
    Polk Lsi9
    Keces DA-131 mk.II
  • Shavon917
    Shavon917 Posts: 2
    A plaintext file, such as a file with a .txt extension, in Microsoft Windows can only have text and no formatted text or images inserted into it. If you're working with this file it will need to be converted into a file format that supports rich text.
    To do this you can save the file as a different file format such as .RTF of .DOC for users using Microsoft Word or Microsoft WordPad. Once the file has been changed, you can follow the below steps for inserting an image into the text file.
  • Shavon917
    Shavon917 Posts: 2
    discount cartridges
  • ken brydson
    ken brydson Posts: 9,063
    Shavon917 reported
