Getting shafted on my broadband
polkfarmboy
polkfarmboy Posts: 5,703
edited October 2012 in The Clubhouse
My net bills as of recent are sky high and now I find myself being overcharged for going over my bandcap. The thing is that I am not downloading anything and today I used up 10 gig for being on polk and facebook ?
Post edited by polkfarmboy on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,726
    edited October 2012
    Wow, you even managed to break your Internet...
    Sorry, couldn't resist
  • chumlie
    chumlie Posts: 8,658
    edited October 2012
    Thats why those limited data plans suck.
    heiney9 Posts: 25,165
    edited October 2012
    HTH do you use 10Gigs just browsing?
  • polrbehr
    polrbehr Posts: 2,830
    edited October 2012
    heiney9 wrote: »
    Hi-Rez **** uses copious amounts of bandwidth...
    *cough* uhhh, I read that somewhere *cough*:eek:
  • ambiophonics
    ambiophonics Posts: 726
    edited October 2012
    Is your wifi network secure? Perhaps a neighbor of yours has been enjoying some HD streaming videos on your behalf...
    2 Channel - Polk SDA-2BTL, Carver TFM-35, Peachtree iDAC, Qobuz streamed via Episode Lynk using bubble UPnP server
  • polkfarmboy
    edited October 2012
    I just called the net provider and he said that last month on the off peak (free) hours there was 180 gig downloaded after 12 pm. Some one is for sure jacking my net and I will find out after some research
  • polkfarmboy
    edited October 2012
    I used that 24 character wep key? I thought that would be secure enough
    EndersShadow Posts: 17,590
    edited October 2012
    I would suggest using WPA or WPA2 and also changing the default gateway, subnet mask and admin logon for your router. All easy things to do. Also constantly check what devices are connected and if you find one thats not yours try to find the MAC address of it and then put it in your MAC filtering list so it can no longer connect even if it has valid credentials...
    That or just get the MAC addresses of all the legit pieces of equipment and put those in and dont allow any others...
  • Drenis
    Drenis Posts: 2,871
    edited October 2012
    WEP is garbage.
    WPA2 as well as MAC filtering here. No one uses my network. :)
  • janmike
    janmike Posts: 6,146
    edited October 2012
    Drenis wrote: »
    WEP is garbage.
    Same Here!
    Michael ;)
    NORTH of 60°
  • simm
    simm Posts: 564
    edited October 2012
    I would suggest using WPA or WPA2 and also changing the default gateway, subnet mask and admin logon for your router. All easy things to do. Also constantly check what devices are connected and if you find one thats not yours try to find the MAC address of it and then put it in your MAC filtering list so it can no longer connect even if it has valid credentials...That or just get the MAC addresses of all the legit pieces of equipment and put those in and dont allow any others...
    How do you do this? Not very computer savvy.
  • nwohlford
    nwohlford Posts: 700
    edited October 2012
    While it may be somebody sharing your wifi, you may also have somebody using your computer as a server for some type of file sharing.
  • polkfarmboy
    edited October 2012
    nwohlford wrote: »
    How can you find that out?
    I took out the router and went into the cable modem and reset everything and then done a speed test and its still down by around 12 gig
  • Drenis
    Drenis Posts: 2,871
    edited October 2012
    What do you use for Virus/Spyware monitoring? Check what processes are running, look for unusual ones with names of which you may not recognize.
    SCompRacer Posts: 8,495
    edited October 2012
    Folks that can't hack into my wireless use my neighbors, Emilio's linksys ****.:lol:
  • codyc1ark
    codyc1ark Posts: 2,532
    edited October 2012
    SCompRacer wrote: »
    Hahahahaha! I like what you did there.
    edited October 2012
    simm wrote: »
    Its going to vary manufacture to manufacture. There should be a location where your router will show a list of all the device names and MAC addresses of items connected to your router at any given time.
    Check your manual.
    edited October 2012
    Well realistically if your in this situation, I would download Avast, Spybot, Malwarebytes along with the new definitions (dont install them yet). Boot into safe mode without networking. This will help ya when you run your scans. Once your booted into safe mode, install all three of those programs and run scans with them (after loading the new definitions).
    See what you get and lets go from there.
    HiJackThis is another good program for finding this kinda stuff and locking your computer down but not exactly user friendly so I wouldnt suggest it unless your decent with computers.
    edited October 2012
    codyc1ark wrote: »
    Really, it was real. Only photoshop was eliminating my network name.
  • polkfarmboy
    edited October 2012
    I ran the malware bytes prog and nothing came up.
  • agfrost
    agfrost Posts: 2,428
    edited October 2012
    That's awesome, Rich.
    Jay
  • codyc1ark
    edited October 2012
    SCompRacer wrote: »
    I saw that, I liked the way you worded it.
  • avelanchefan
    avelanchefan Posts: 2,401
    edited October 2012
    What router do you have? You should be able to log into it and see what devices are running off of it.
    And 180gb of Data download? Even I don't run anywhere near that.
    Sean
    XboxLive--->avelanchefan
    PSN---->Floppa
    http://card.mygamercard.net/avelanchefan.png
  • gdb
    gdb Posts: 6,012
    edited October 2012
    What sort of distance is "safe" from having neighbors being able to tap into a home's wireless network ??
  • nwohlford
    edited October 2012
    Go into the network control panel and see the amount of sent data under your current connection. Unless you upload a lot of files this should be realitively small.
  • polkfarmboy
    edited October 2012
    So today my bandwidth used is only 400 mb compaired to the 5,6 and 8 gigs I have been getting hit with. My wifi is off so its for sure being jacked
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited October 2012
    Now you've done it. Patrick was running the forum on your system.
  • WilliamM2
    WilliamM2 Posts: 4,773
    edited October 2012
    Do you really need the Wi-Fi? I only ask because you say it's off now. If not, leave it off.
    Otherwise:
    Don't broadcast your SSID.
    Use MAC filtering to only allow your own devices.
    WPA2 encryption, with the longest randomly generated password allowed.
    Limit the number of connections to the amount of devices you have.
    If someone is really determined and has the knowledge, they can still get in. But this will stop most, as they will move on to an easier target. WEP can be broken in minutes with freely available programs.
    Clipdat Posts: 12,933
    edited October 2012
    Not broadcasting the SSID doesn't really do much truthfully. In fact, it actually causes devices like your laptop where the SSID is stored to adhere the network name to part of it's packets, so that when you are in a public place looking to connect to a new Wi-Fi signal, you are actually inadvertently broadcasting the name of your home network around.
    From: http://www.howtogeek.com/howto/28653/debunking-myths-is-hiding-your-wireless-ssid-really-more-secure/
  • WilliamM2
    edited October 2012
    Clipdat wrote: »
    Like I said, if someone's determined, they can get in. Why would I care if my laptop is leaking the name of my network when I'm miles from home? How would that help anyone connect easier than just broadcasting it? WPA2 is the best deterent, and I included it.
