Help Needed: Whole House Water Filter Recommendations
toucanet
toucanet Posts: 580
edited October 2012 in The Clubhouse
I am in the market for a whole house water filter system and am interested in recommendations and any other advice.
The house is a ranch with four full bathrooms outside of Atlanta, GA.
Thanks in advance.
Post edited by toucanet on
  • Gadabout
    Gadabout Posts: 1,072
    edited October 2012
    I might be able to help a bit, but you choose the word filter and that brings up some questions.
    Like what are your expectations for the filter? What do you need to get rid of?
    It's vastly different solutions for a location that is in the sticks, needing to purify pumped pond water vs a home in a subdivision that has a little too much iron in the water. Also, since you said filter, I'm assuming that your not interested in a water softening system?
    Scott
    Ohhh Post 999 ... is that the opposite of 666?
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • toucanet
    toucanet Posts: 580
    edited October 2012
    Hi Scott,
    I am trying to reduce the amount of iron that is coming into home from the faucets. The local government provides the water to our subdivision. Periodically, we get mild amounts of sediment due to rehabilitation of water pipes by the local government and am tring to reduce the "surprises" when I run the water in my house.
    You are correct in your assumption that I am not interested in water softening; strictly filtration.
    All of the pipes are copper
  • Drenis
    Drenis Posts: 2,871
    edited October 2012
    Reverse Osmosis
  • oldmodman
    oldmodman Posts: 740
    edited October 2012
    Drenis wrote: »
    Reverse Osmosis
    Very expensive and not generally required with city water that meet the federal clean water standard. It would be the ultimate system if you wanted to spend the money.
  • amulford
    amulford Posts: 5,020
    edited October 2012
    Well an iron removal and filtration system usually uses a resin bed which will have to be changed periodically.
    I'd have a water test done first so you can find out what the iron content actually is. Then pick a system based on that.
    tonyb Posts: 33,019
    edited October 2012
    oldmodman wrote: »
    Yes and no, those standards while in place to ensure a level of safety in our drinking water, don't cover the gammit of everything that could possibly be in it. Almost impossible for it to do so anyway, hence the aftermarket filters. Heard nothing but good things from people who use the Osmosis system and if your wallet dictates, I'd go for it.
    The thing with whole house filters to keep in mind is the cost of replacing those filters and how long they will last.
  • amulford
    edited October 2012
    I personally would only use it for water you are going to consume. It's not a very efficient method, it's actually kind of wasteful. Great system, but not for a whole house yet...
    tonyb Posts: 33,019
    edited October 2012
    I dunno Antny. You've seen what the lack of clean filtered water did for Honey Boo Boo ?
  • amulford
    edited October 2012
    Nah. To be honest witcha, IDGAF what happens to Honey Boo Boo.:lol:
  • rpf65
    rpf65 Posts: 2,127
    edited October 2012
    Not my line of work, but if your trying to filter various particles my suggestion would be to go to Home Depot, and get 2 filters. I'ld place them in line with each other, about 2 feet apart, and in the first use one of the less expensive filters. That woould trap most of the sediments, lime and iron. On the second I would use one of the carban filters, for finer particulate removal. You would probably double the life of the carban filter that way.
  • del44
    del44 Posts: 686
    edited October 2012
    I have a reverse osmosis system for drinking water and ice maker, couldn't be happier. But I am seriously thinking about going with this http://www.lowes.com/pd_31217-43353-WHELJ1_4294822071%2B4294819817%2B4294821330__?productId=1082883&Ns=p_product_qty_sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo=Whole house|Complete system. I have an inline filter but i think this will really be an improvement.
  • Hobbyguy
    Hobbyguy Posts: 317
    edited October 2012
    We had Kinetico (http://www.kinetico.com/) test our water then installed filters for our whole house and RO for our drinking water/refrigerators/ice makers...could not be happier. I'm sure any reputable company that recommends testing your water first then recommendations based on the testing would suffice.
  • toucanet
    toucanet Posts: 580
    edited October 2012
    Keep 'em coming!
    Thanks for all of the advice to date. I have sent emails and left messages with several companies requesting them to come to home, test the water then make recommendations.
