10Bs with Stands and one bad tweeter
rccolburn
I was looking for a pair of stands for my Monitor 10s and ran across a pair of 10Bs with stands but one non functioning tweeter for $100. Are replacement tweeters still available? I'm thinking the stands alone might be worth it but can I repair the tweeter? Might make nice rears in my surround system.
Post edited by rccolburn on
Repair -- may be impossible.
Replace -- yes, polk has replacement/better tweeters.
Silver dome SL2000 = RDO-194.
BTW mention you are a club member and u get a discount! Also if you dont want to replace both tweets ( which u must if you go to the replacement rdo-194's you can buy a replacement original fron some members sl2000 are easy to find used here on the cp.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Well I picked these up for $60. Now my 10s have stands! Not sure what the difference is between the 10 and 10B monitors is. They appear identical. I have determined that the tweeter is indeed dead. Swapped them to be sure.
How much of an upgrade are the rdo-194s? Is it worth an the extra expense? From what I have read they run around $50 each. Not sure what a single SL2000 would cost if I can find one. -
Unfortunately I can't check the classified for an SL2000 because I have less than 100 posts.
Yea the 194 are $48 + tax free shipping. They are well worth it. Ask for Helen mention Club Polk.
nspindel may still have a pair of old sl2000Well I picked these up for $60. Now my 10s have stands! Not sure what the difference is between the 10 and 10B monitors is. They appear identical. I have determined that the tweeter is indeed dead. Swapped them to be sure.
How much of an upgrade are the rdo-194s? Is it worth an the extra expense? From what I have read they run around $50 each. Not sure what a single SL2000 would cost if I can find one.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
