PS3 Audio import
snake1
snake1 Posts: 567
edited October 2012 in Electronics
Hey guys, got a few questions about audio import settings on my PS3. What codec should it be: aac, mp3, or atrac?
What bit rate : 96, 112, 128, 160, 192, 224, 256, 320?
Output freq : 48khz or 44.1/88.2/176.4khz?
Bitmapping?? Type 1, 2, or 3
(the ones it red are current settings)
This may not make a hill of beans difference in the audio, but if it does I want it to be right. I save all my good audio to it for playback at times. If it really doesn't matter, just let me know.
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
Post edited by snake1 on
    Clipdat Posts: 13,101
    edited October 2012
    Could you describe your "audio import" steps? Is it some sort of audio capture function?
    heiney9 Posts: 25,630
    edited October 2012
    Since they are low bit rate mp3's, it won't make a bit of difference. There is no place for mp3's in a serious audio system
    edited October 2012
    heiney9 wrote: »
    320s aren't that bad.
    edited October 2012
    Clipdat wrote: »
    Yes, they are. Any mp3 sucks a$$ if high fidelity is what you're looking for. There is no place for lossy audio if you are the least bit serious about good sound.
    Period!
    edited October 2012
    Well, I would generally tend to agree with you.
    That being said, the difference between 128 and 320 is dramatic. At first I had no issue with 128-192 mp3s. Now I can't stand to listen to any mp3s below 320.
    However in my experience the difference between 320 and FLAC is much much less dramatic.
  • Thorton
    Thorton Posts: 1,324
    edited October 2012
    Clipdat wrote: »
    Agree, and for high fidelity yes, lossy may not be the way to go. But when you try to support a library to your main 2 channel, 2nd 2 channel, garage, boat, car hard drive, older mp3 player and phone, I enjoy the compatibility and sound of 320. It all depends what your looking for.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • snake1
    snake1 Posts: 567
    edited October 2012
    Clipdat wrote: »
    Well I guess its whenever files are loaded from the LAN or from a usb drive.
    heiney9 wrote: »
    Period!
    There is DEF room in my 'serious' system for some mp3s especially for my budget!! MP3s sound dang good as a matter of fact! I'm just trying to do the best with what I have.
    So what y'all are telling me is bascially to switch to the the 320 and let it go? I'll make the change and thanks for the info!!!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
    edited October 2012
    Yep, exactly. Just bump it up to 320 and your ears should thank you.
  • snake1
    snake1 Posts: 567
    edited October 2012
    Sounds good! Thanks fellas!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
    edited October 2012
    Late to the show. But as far as what you can "store" on a PS3 and what I have on there, as well, 320 is your best option. Wish Sony would not put a limit on that, but they're neurotic about copy protection. I would like to be able to put lossless on there and run the digital to a better DAC, but?
    Have fun!
    cnh
