Any Aftermarket SDA SRS cables?
trav0810
trav0810 Posts: 1,056
edited October 2012 in Vintage Speakers
I know that none of the big companies like Monster make a replacement cable for these, but does anyone know of any custom cable makers that have managed to reproduce these?
The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects
Post edited by trav0810 on
  • gdb
    gdb Posts: 6,012
    edited October 2012
    Polk sells the blade/blade version, the pin/blade are scarce and show up in the FM every once in a while........you've only got 98 more posts to go before you can get in there.
  • trav0810
    edited October 2012
    Of course I need the pin/spade for a pair of SRS 1.2's I just bought. I need a few things....they are in rough shape, but they are the speakers I have wanted for years. I guess I better get to posting!
    Thorens TD320
    Modified Carver C-1
  • PolkieMan
    PolkieMan Posts: 2,446
    edited October 2012
    only the pin is active the blade is just for support I use a RCA cable because of the pin, just break the outer rings off, just be careful moving them around as only the pin is supporting the cable
    trav0810 wrote: »
  • cincycat13
    cincycat13 Posts: 887
    edited October 2012
    If you are using a common ground amplifier, you only need to connect the "pin" portion of the pin/blade connection.
  • trav0810
    edited October 2012
    Thanks for the info! You guys have been most helpful.
    Thorens TD320
    Modified Carver C-1
  • Phasewolf
    Phasewolf Posts: 514
    edited October 2012
    I am thinking about removing the pin blade connectors and replacing it with a speakon connector.
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
  • eandrade
    eandrade Posts: 20
    edited October 2012
    PolkieMan wrote: »
    Hi PolkieMan,
    I recommend that you consider upgrading the RCA cable to a good quality speaker cable. I ran an RCA cable for about a year before finally installing Cardas binding posts and building my own interconnect out of 12 gauge speaker cable -- I'm slapping myself for not doing it sooner. The improvement to the overall SDA effect was HUGE.
    -Ernie
  • Oldmanind
    Oldmanind Posts: 49
    edited October 2012
    Did you the ones near south bend?
  • trav0810
    edited October 2012
    Maybe. They were East of Fort Wayne.
    Thorens TD320
    Modified Carver C-1
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited October 2012
    If you don't have the wherewithal to build yourself a set of far better than stock cables, as suggested in this thread, I suggest you do a Google on VR3 Mods and talk to Trey about what he recommends for you. He can be helpful in doing other mods you may want to do.
    By the way, nice to see another Hoosier on the Forum -- I'm a native son of Bedford, Indiana -- who is currently in the midst of modifying a pair of SRS 1.2s and a pair of 1Cs -- with a lot of help from the much more knowledgeable members of the Forum and VR3 Mods.
  • trav0810
    edited October 2012
    Teekay referred me to Trey as well. I will be reading some of his posts. I appreciate the help!
    Thorens TD320
    Modified Carver C-1
  • trav0810
    edited October 2012
    by the way; How is your project going?
    Thorens TD320
    Modified Carver C-1
  • Moose68Bash
    edited October 2012
    Both projects are progressing, albeit not at the pace I would like.
    My SRSs were purchased about a year ago, and by all appearances they were in excellent condition and had never been modified. Trey has built the upgraded crossover and binding post cups, and they are ready to reinstall. We are waiting for delivery of the perfect-lay SDA inductors. I have RD0194s to replace the tweeters. MWs and PRs have been treated with Dynamat Xtreme. MWs will be treated with JB Weld before I reinstall them.
    However, when I removed the PRs, I discovered that the SRSs had been modified and had suffered some damage to the cabinet of the right channel speaker and the gasket was destroyed. I am now repairing that damage. I also discovered that the amount of polyfill in the upper part of the cabinets had been approximately doubled. More important, egg-crate style foam had been added to the PR portion of the cabinets. All that filler has been removed, and I have new Accousia Stuff (and less of it) to reinstall. I'll add Black Hole 5 behind the MWs and tweeters, as well as on the cabinets' interior sides at the level of the MWs. I've ordered neoprene to cut new gaskets. I have sets of Larry's rings to install, which I will do as soon as the cabinet is repaired. Finally, I'll add spikes to the bases and get the SRSs put back together!
    I purchased the 1Cs new in 1989. I haven't found any surprises with them. Trey has the crossovers and binding post cups to rebuild. I have RD0194s to replace the SL2000 tweeters. I will apply Dynamat Xtreme to the MWs and PRs, and Black Hole 5 in the upper back and sides of the cabinets, install Larry's rings, new gaskets, install spikes and reassemble the speakers.
    As an aside, I have built one Dreadnought and will built a second one when the Avel Lindberg 1000VA isolation transformers nspindel has organized. I've got one of Larry's cases on order, and am building one of my own design (I ordered the parts before I knew that Larry was making cases). I've used both sets of speakers with the Dreadnought, and I believe it produces superior sonic performance -- even when it is not necessary to enable the SDAs to be used with a non-common-ground amplifier or amplifiers.
    Sorry for the length of this, but I guess I got started telling you how it was going and couldn't stop!
    VR3 Posts: 28,782
    edited October 2012
    Your inductors will be potentially Saturday or Monday...
    Ohhhhhhhh snap!
  • trav0810
    edited October 2012
    Very nice. I spoke to TeeKay earlier today and he was telling me about the dynamat and jb weld and also about Larry's rings. I am sitting down and making out my Christmas list!
    Thorens TD320
    Modified Carver C-1
  • PolkieMan
    edited October 2012
    I am, it is on my winter list. I just got my Part Express cat so I will be looking into that soon, thanks for the suggestion
