bass shakers
dholmes
dholmes Posts: 1,136
Does anyone own the Aura 50watt bass shakers? If so how do they sound? Do you hook them up using the sub out jack? Also Partsexpress sells sub amps starting at 100.00, would one of them work?thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited November 2003
    They don't sound, they vibrate / shake. You can hook them up via LFE, or any full-range preout.
    And yes, pretty much any amp will work with them.
  • Airplay355
    Airplay355 Posts: 4,298
    the rti150s arent enough for you? lol
    they shook the hell out of my tiny room and that was with them running off a receiver lol.
  • dholmes
    Yes the 150s do a great job with bass, Years ago I seen Earthquake the movie with the seats that vibrated. I think it was called sense around something like that just wanted to know if they did a good job of shaking the seat, or was just a gimmick ! thanks
  • Seaward
    Seaward Posts: 56
    how much do the bass shakers cost (range)??
    Do you guys know of any suppliers in Canada?
  • dholmes
    You can get them at Parts express. The 50watt cost 25.00 each & the plate amp was 100.00 I thought for 200.00 for everything & if I hated them thats not too much & wasted, & I might like them !!
