tehcnics sl 1350, OPINIONS NEEDED, ASAP!!!
EDUBAG
EDUBAG Posts: 403
edited October 2012 in 2 Channel Audio
Hey guys,
i have the opportunty for picking one of this turntables on excellent condition for 75 bucks. But sine i do not know a lot about them i am asking you guys in the forum if any of you have any experience (good or bad) with this turntable.
Things to look for, weak point, strenghts, etc. Most important how does it sound? Will it be an upgrade from my pio pl100 or more of a lateral move etc. I plan on using a denon dl110 cart with it.
Thanks for the input
eduardo
HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES
Post edited by EDUBAG on
  • SDA1C
    SDA1C Posts: 2,072
    edited October 2012
    I'd do it for 75 bucks.
    Too much **** to list....
    mhardy6647 Posts: 35,046
    edited October 2012
    as would I - perfectly decent albeit old-ish Technics turntable - if the condition is good overall (arm not distorted/bent, headshell alignment OK, and minimal play in the bearings) and it runs - it is well worth 75 smackers in the current market. The speed control pots might need to be cleaned if it runs but seems to "search" rather than hold speed. Not sure if this particular Technics develops such symptoms (but many of them do).
    That's a fully automatic deck/changer - check to see whether it has both the single-disc and the multi-disc spindles.
    You'll find a little info on this page http://www.vintagetechnics.co.uk/turntables.htm
    I don't know the PL-100, sorry.
    The Technics would be a good match for the DL-110 in terms of arm mass/system compliance.
