Cambridge vs. NAD vs. Music Hall
crouse
crouse Posts: 34
edited October 2012 in 2 Channel Audio
For any who have experience with these brands, which one would you recommend? I'm looking for an integrated amp around $500 and they all have models close to that price. I'm also thinking about a budget tube amp, but that's for another discussion...
Post edited by crouse on
  • coolsax
    coolsax Posts: 1,826
    edited October 2012
    I like my Music Hall A15.2 a lot.. its got good power for a small to med sized room and plenty of inputs, including a phono. Only complaint is i wish it had A&B speaker outputs, also if your looking to use them with the LS50s you posted. you'll have no problems, as I've driven some 50s with it as well.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • crouse
    crouse Posts: 34
    edited October 2012
    Thanks for the info
