Is this safe?
SebastianG
SebastianG Posts: 14
edited October 2012 in Speakers
im thinking of puting my rm8's on my top rear wall with these brackets http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082804&p_id=6839&seq=1&format=2 + the wall mounts that come with my rm8's . Question is would this be safe or would the bracket break and drop my speaker
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited October 2012
    Those brackets will support 33lbs. What do your speakers weigh?
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • SebastianG
    edited October 2012
    2.8 pounds
    edited October 2012
    If those brackets support that they should have NO problem with a few pound speaker like an RM8 satellite, except for perhaps its odd shape? Those Polks weigh almost nothing and present no real structural support problems for most brackets? Just about "any" bracket would support that weight!
    cnh
  • SebastianG
    edited October 2012
    yeah the reason i had to ask was cuz i dont know if it would be recommended to use the Monoprice brackets and the plastic wall mounts together
    edited October 2012
    I see what you're saying. Do you have the RM8s and are wondering if they'll "fit" the monoprice brackets (slots, screw, etc.)? Because I wouldn't know without seeing both pieces next to each other.
    cnh
  • SebastianG
    edited October 2012
    they fit just fine i had to buy a longer screw but im just wondering if they will hold
