7.1-5.1 Setup on odd room
SebastianG
SebastianG Posts: 14
im moving into a basement and my home theater area is odd anybody have any tips or setups to make it the best possible i can eather use 5.1 or 7.1
Post edited by SebastianG on
  • badchad
    badchad Posts: 348
    edited October 2012
    I'm not quite sure where the problem is. Place the rears on the walls on the side(s) of the couch. If you opt for 7.1., place the rear surrounds on the back wall.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • SebastianG
    edited October 2012
    i have no side walls the couch in next to a fire place and the other side is opened also my rear speakers are Wide Dispersion Array speakers
