LSi-15's - Speaking of Synergy...
stretchl
stretchl Posts: 1,334
edited October 2012 in 2 Channel Audio
Get it? "speaking" ? ;)
But seriously folks...
For those of you out there who have LSi-15 speakers, what amp do you have and how do you like the combination?
The Parasound v. Adcom discussion that grew out of a For Sale thread has got me wondering about my LSi-15/GFA-555ii pairing.
As I mentioned there, sometimes the highs grate on me, though it's possibly due to my tinnitus rather than the gear.
Thanks.
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
Post edited by stretchl on
    tonyb Posts: 33,027
    edited October 2012
    Adcoms were never known for their lush highs, But like everything else, try something different to see what floats your boat. Have the same infliction as you so I tend to be more drawn to warmer sounding gear.
    Have you tried anything other than the luxman in the mix ?
  • acmf74
    acmf74 Posts: 936
    edited October 2012
    I have been using the Adcom 5802 with the LSi-15s. Excellent results.
    heiney9 Posts: 25,221
    edited October 2012
    Adcom and LSi's are a great match. I'm betting if you have tinnitus, that's the issue. I would also suspect your apple lossless files and the Luxman receiver you are apparently using for a pre-amp. You have other issues to consider before blaming the amplifier.
  • hochpt21
    hochpt21 Posts: 5,423
    edited October 2012
    You can see what I am using in my gear. I havn't heard the 15's with anything else, so I can't compare, but the highs definitely don't grate on me. I really like what I am hearing, and from what I've read (not experienced) that may be the B & K warming it up a bit.
  • stretchl
    edited October 2012
    Ahhh... good ideas...
    Now I'm wondering about the Luxman.
    This may be a stupid question, but can I just take the pre-amp out of the equation completely and, as a test, run the DAC directly into the Adcom?
    ie -
    Squeezebox --> TubeDAC --> GFA-555ii --> LSi-15's?
    I don't want to blow something up.
    Thanks very much!
    - Isaac Asimov
    Hi-Fi
    Visuals
    EndersShadow Posts: 17,596
    edited October 2012
    stretchl wrote: »
    ie -
    Thanks very much!
    I believe this is possible since the Squeezebox does have a volume control. Others will chime in.
  • stretchl
    edited October 2012
    That's what I'm thinking too, Dan. There's also a volume control on the TubeDac.
    I'll wait for confirmation before I try it, but it should be an interesting experiment.
    - Isaac Asimov
    Hi-Fi
    Visuals
    tonyb Posts: 33,027
    edited October 2012
    Won't hurt to try, but my suggestion is to leave the volume control on the SB to fixed and use the volume control on the dac. Usually the volume control on devices such as a SB or Sonos are fairly noisy and very noticeable in the higher volume range.
  • stretchl
    edited October 2012
    That's what I'm thinking too, Tony.
    - Isaac Asimov
    Hi-Fi
    Visuals
    edited October 2012
    You could try it, but the results probably won't better and might be worse. You can't sub these types of things (SQB and inexpensive dac) for a good pre-amp. You can't cut corners on the pre-amp and expect it to sound good.
    Just my .02c and my experiences.
  • stretchl
    edited October 2012
    heiney9 wrote: »
    I don't understand.
    You're saying that a good pre-amp is better than no pre-amp?
    - Isaac Asimov
    Hi-Fi
    Visuals
    tonyb Posts: 33,027
    edited October 2012
    I think what Brock means in your situation, is try another pre amp. Yes a good pre amp for digital is a gimme but still won't hurt to try it the way you want to. If anything, you'll either like it/hate it, but you will appreciate better what a pre amp does for the sound.
    Never hurts to experiment.
    edited October 2012
    stretchl wrote: »
    I don't understand.
    In the specific cases you are talking about, yes. You are using a very inexpensive and not very well implemented digital I/C chip in the SQB to control volume. With the dac, it's an inexpensive volume control and not much care is taken to implement it, not like a really good pre-amp. I'd use the Luxman receiver before I'd use the vol control on the SQB. Always leave it at full volume to get the best performance.
