RM5000 Wire Connections
cdwellers
Hello.
I purchased a satellite system from Polk a while back.
It was (i think) the RM5000 - it had 2 satellites and a subwoofer.
Well I moved into an apartment and I forgot how to conect the wiresto my Sony receiver so I can get maximum sound response. Does anyone have instructions to connect it or maybe the original manual in pdf format? My receiver has left/right, 2 center and 2 rear outputs but no subwoofer out. I seem to remember some special way to wire the subwoofer but I've tried several ways and i can't get it to sound right.
any help would be appreciated.
Thanks and happy holidays.
Kurt
Kurt
Post edited by cdwellers on
welcome to the forum, kurt!
joe
Hi Kurt this is Jason from Polk Audio. Yes I can make a copy of the manual and send you one. Email me your address and I will get that out to you. By the way you would run + and - speaker wires from your right and left front outputs to the sub then run speaker wire from the sub to the front speakers. Set you sub on your receiver to "off" or "none" and select the "large" setting for the front speakers. If you need anything else include it within your email.
J
jmelani@polkaudio.com:cool:
