Monitor 5, M7A and Monitor 10
Frankie1958
I am a proud owner of a third set of Polks the m7A, which I acquired in a garage sale for $25.00. I replaced my Monitor 10 set with these older 7A's that sound just great. They are in very good overall condition but the tweeter button on of the speakers is flatened but it does appear to affect the performance of the speaker. I would like to know what tweeter I have as its is all black nothing written, no hole in the middle of the button.
thanks in advance,
thanks in advance,
Post edited by Frankie1958 on
Can u post a pict? Sounds like it may be a peerless but without seeing cant be sure.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
The monitor 7's original black tweeter was made by Peerless. I have a pair of 7's myself with that tweeter.
Thanks for the reply. I am new to this site I will try to send you a picture.
All black should be peerless, but they do have a small pin hole in the center of the dome. Need pics to confirm.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
That's not a peerless. Looks to be non original replacement. Not sure- have you removed it to look for markings on the rear?2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
Hi! I have never removed a tweeter. I will give it a try. I am very curious.
I removed the tweeter and at the back it is written DMT 700 60W made in Taiwan. R.O.C. I searched for info on these but cannot find anything. Does somebody have info to share on these tweeters? Would I get better sound if I replaced them with Polk tweeter?
Thanks Again! -
Frankie1958 wrote: »I removed the tweeter and at the back it is written DMT 700 60W made in Taiwan. R.O.C. I searched for info on these but cannot find anything. Does somebody have info to share on these tweeters? Would I get better sound if I replaced them with Polk tweeter?
Thanks Again!
Yes, you would get a better sound with Polk replacement tweeters. Not sure which tweeters would fit these electrically (possibly RD-0194), but I'm sure others will chime in.
That's a hack repair job."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
You might need to take a look at your crossovers or the date on the mid-woofers to help determine what was the stock tweeter. I know from experience that the Peerless and the later RDO tweeter are not the same size. The RDO (and the Sl2500 that it replaces) are a little larger. I did the replacement and had to enlarge the tweeter cut out a little. If the crossover has just one 2.7 ohm resistor in the tweeter circuit you can probably drop in the RDO tweeter. If there are two resistors in the tweeter circuit you probably had the earlier Peerless tweeters. I happen to have a pair of Peerless tweeters in fine shape available if that is that you need. Good luck.
I called Polk customer service and the woman I talked to said the 7A's came with the Peerless HF1000 tweeters. She also said I could replace the taiwan tweeters with the SL-2000 from my monitor 10,s. They are in good working condition so I am kind of reluctant to take them apart. How much I am looking to pay for a pair of Peerless tweeters? I am in the Ottawa area Canada I wonder about shipping cost also.
Thanks! -
Peerless tweeters are often up for sale on E-bay, if you don't mind going that route
you may also want to post in the 'wanted to buy' section of this forum - there are a lot of great folks who can help you out. Fellow Polkies have helped me many a time with parts, for extremely reasonable prices, much less than eBay.HT System:
Marantz NR-1403
Front: Klipsch CF-4
Rear: Paradigm Atom V3
Center: Boston Acoustic VR12
Sub: Bowers & Wilkins ASW600
2Ch:
Restored Fisher 500C
Yamaha P-500 Turntable
Living Room:
Harman Kardon 3380
Restored Polk Monitor 7B
Bedroom:
Harman Kardon VR-3750
Cambridge Soundworks Ensemble
Polk PSW10
In and out of rotation:
KLH Model 6,
Polk LSI7
NAD 7100
