What amp would be good?
Systems
Systems Posts: 14,873
edited December 2001 in Car Audio & Electronics
I recently bought a 95 GTI, and would like to upgrade the stereo. I was thinking of putting a MM455 up front and a MM465 in the rear, with 2 MM100 in the trunk for my base. What would you suggest I use for an amp? I was recommended the Xtant amp. Is this a good choice, and will it be enough for the set up.
Any input appreciated.
Aaron
Testing
Testing
Testing
  • osiris6910
    osiris6910 Posts: 9
    hey, i got 2 momo 10's for sale, 260 for both. only used for a weak. had only 125 watts goin to em.
    let me know if you are interested.
    osiris
    osiris
  • blu_viper
    blu_viper Posts: 18
    darn kim beat me to exactly what i was going to say. I would not recommend using a 5 channel amp for any system that wants lots of power. they aren't able to produce the power a system like that would need. also just having one amp doesn't look as good i've got a hatchback camero with my two amps set like a triangle shape and my cap and crossovers inbetween the amp and it looks really cool with those neon accent lights!
