sl2000 ohm
kidglove13
kidglove13 Posts: 207
edited September 2012 in Vintage Speakers
Cant seem to find the info
What ohm is an sl2000 tweeter in a SDA 1B?
It does not say on the back of my sl2000's
Post edited by kidglove13 on
  • nhhiep
    nhhiep Posts: 877
    between 6.9-7.1 on my 3 sl2000s
  • kidglove13
    Which means it is effectively a what ohm speaker?
    Does that mean it is an 8 ohm speaker?
    heiney9 Posts: 25,217
    No, he's just measuring dc resistance. Ohms vary with frequency so the best you can do is get a median reading. A 4 ohm speaker is not 4 ohms all the time, it varies with the frequency of the signal played through it.
  • kidglove13
    H9, so the sl2000 in my 1B's are 4ohms then since the speakers are 4ohms correct?
    No, not necessarily. The nominal impedance of the entire system is 4 ohms. Why do you need to know?
  • kidglove13
    Not for any particular reason
    I just like to learn as much as I can about something I own, thats why I come here for answers when I do not know something.
    Especially when I am going to take my 1B's apart some time in the near future, once I finish redoing my monitor 7's so that I will at least have something to listen to when my 1B's are down
  • Schurkey
    Schurkey Posts: 2,104
    kidglove13 wrote: »
    Dump the SL2000s, replace one (the 4.4uF) capacitor in each HF crossover board with a 5.8uF, and then install SL3000/RD0-198 tweeters.
