SDA SRS NOOB in the house
Dabutcher
Dabutcher Posts: 2,597
edited February 2014 in Vintage Speakers
I just picked up my first pair of SDA SRS and they are minty and have eight woofers and one passive and four tweeters. Guy says 1989? What model and can I make my own interconnect? Pin /blade type.Will the wrong amp wreck them or only when interconnect is attached? I have Pioneer spec 2,Onkyo M504,emotiva XPA-2 for amps I own?>.....................as always thanks for any help,Darryl:mrgreen:
Post edited by Dabutcher on
  • michaeljhsda2
    michaeljhsda2 Posts: 2,186
    edited September 2012
    Congrats. You actually have at the very least SRS 1.2's and possibly 1.2 TL's. Remove one of the tweeters and if it's says SL 3000, you have 1.2 TL's. If it's an SL 2000 tweeter you have 1. 2's (which can be upgraded to 1.2TL'S with the appropriate mods).
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Mystery
    Mystery Posts: 2,546
  • smglbrth
    smglbrth Posts: 1,481
    If you picked those up on Craigslist, congrats. I saw them earlier today. Those are the standard 1.2's, not the TL's, those in the ad anyway.
  • Dabutcher
    Attachment not found.Attachment not found.How do I know a common ground amp? And what makes these so so very heavy? Thanks. D.
  • drumminman
    drumminman Posts: 3,396
    Re: what makes them heavy, they're b-i-g! ! ! ! with lots of drivers, big inductors and the cabs are made of mdf = heavy.
    Re: common ground determination, check with your amp manufacturer. Or if you have a multimeter you can check it yourself: set it to the lowest ohm reading, touch one probe to the right negative speaker terminal and the other one to the left negative speaker terminal. The reading should be 0 or close to it.
  • Malbec
    Malbec Posts: 554
    http://vr3mods.com/LCSDAUpgrade.html
    Start here with Trey's website. This is required reading for the SDA owner. Get an accordion file (or two) since there will be more than a couple of threads you'll want to pour over and keep as reference material. Get a highlighter too.
    You can also go to the bottom of the page you're on and check out the similar threads.
    Have fun getting lost in all the information:cheesygrin:
  • michaeljhsda2
    The red binding post nuts should be on the left, not the right (some of the 1.2's that were released from the factory had the red binding post nuts mistakenly installed on the right). Even if the sticker on the back of the speakers show that red is on the right, ignore it. The sticker is from the original SRS's as Polk is known to use leftover stock on newer model speakers.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • vcwatkins
    vcwatkins Posts: 1,993
    Holy cow! How did I miss this?! I was ready to move the 1.2's out of the den and put the 2's back, thinking the 1.2 crossovers needed work or wiring checked. Did a quick switcheroo and, presto glorio, the soundstage blooms to what I had expected from these big boys all along. Aaaaahhh...
    I had tried about every placement option I could think of. It never sounded like the SRS2's though, and since I removed the 2's and a huge 3-unit wall cabinet at the same time, I thought that might have something to do with it. At least I put some more hours in listening to the LsiM-707's. I now know I much prefer the 1.2's (as someone here had predicted), and can feel better about the decision to sell the 707's.
    Anyway, problem solved! Many thanks MichaelJ! You saved me a lot of time and aggravation (and prolly my back too, snicker). This place is great.
    Craig
    b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
  • michaeljhsda2
    You're welcome Craig. Enjoy!
    SDA SRS 2.3TL's
    SDA 2B TL's
  • GlennDog
    GlennDog Posts: 3,121
    vcwatkins wrote: »
    Isn't it ?
    G
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • Dabutcher
    edited October 2012
    Finally have them installed on either side of my Mitsubishi . Sound great! I have read that they should be as close to rear wall as possible. That's where I had them and they sounded great. But I am guessing that the front should not be behind face of TV? With the rear projection I cannot have both? Thank you everyone for all your help. Wife says they are way too big? Her and I will work through that together. This community Rocks!
  • OldmanSRS
    OldmanSRS Posts: 419
    edited October 2012
    Mine were that way and for 14 years I had no SDA operation due to connecting them the wrong way. They work OK reversed but there is NO SDA! I found the problem when I moved here and accidentally connected them "backwards" and the SDA suddenly started to work. Feakin AWESOME improvement. Best mod I have ever done :)
    '65 427 Shelby Cobra
    '72 Triumph TR-6
    __________________
    '88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
    '86 Polk SDA CRS+
    '84 Polk Monitor 10A (Peerless tweeters)
    '05 HSU VTF-3 Sub (Original OEM)
    '20 HSU VTF-3 Sub (three more, 100% cloned)
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    '88 Adcom GFA-555 (upgraded/restored)
    '88 Adcom GFA-555 (a second one upgraded/restored)
    '05 Onkyo DV-555 media
    '89 Fosgate 360 Digital Space Matrix
    '89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
    '91 Kenwood Basic M1D Amp
    '89 Pioneer Laser Disc media
    '89 Sony SuperBeta HiFi media
    One PGA2310 based custom built remote volume control
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
  • Deadof_knight
    Deadof_knight Posts: 980
    Awesome dude enjoy ! lots of info here and everyone is great
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • VCoak
    VCoak Posts: 200
    Congrats on your 1.2's. I too for almost 20+ years had my + and - backwards. Hooked them up correctly and amazed. Building my own Dreadnaught and once completed will be headed to Vr3 for crossover upgrades and more.
    I am a Newbie and have read so much in the past month. Great folks here and answer quickly and knowledge. They been there done that. Helps me out so much.
    Enjoy them!
    W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
  • j1mmy
    j1mmy Posts: 95
    Nice starter pair for sure! Congrats.
