Speaker placement help needed
Currently my desk is an array of computer monitors and the only space i have for some book shelf speakers is if i wall mount them above the monitors. I would have to point them down at a 20 deg angle to properly aim them. Is this ok? I was looking at the pinpoint am40's but they only do 7 degs.
The other option i have is to rotate the towers off the desk and have a pretty wide stage for the two speakers. With this setup they would be ear level.
Which of the two would be better?
Thank you ><
Thank you ><
HT: M5510-Prox2/PN51E550/NR708/M282(3)/RTi A7/CSi A6/FXi A6/DSWPro660x2/PS3/HTPC
Office: Belkin PF60/PN43E450/Marantz 1501/PSB 400/Image C4/WD Live TV
2-Channel: Yamaha C4/M4(2)/DQ-10's/DQ-1w(2)/SBT/Pioneer R2Rl/Technics SL-7/AR EB101
Desk: QSC RMX850/Behringer B2030P
Mounting them on the wall above the monitors would be fine. You could also consider a speaker like the JBL L820 which is fairly flat and meant to be hung on a wall.
Honestly its the behringers 2030's that im trying to find a position for ><HT: M5510-Prox2/PN51E550/NR708/M282(3)/RTi A7/CSi A6/FXi A6/DSWPro660x2/PS3/HTPC
Desk: QSC RMX850/Behringer B2030P -
I prefer a wide sound stage, so I would got for that option. I have found my Behringer speakers great for computer duty, so good luck with the placement.
