Adcom 545II power cord
kidglove13
kidglove13 Posts: 207
Can I retro fit a better power cord to my Adcom GFA 545II ?
Would it be worth it to even do it?
Post edited by kidglove13 on
  • dorokusai
    dorokusai Posts: 25,576
    edited September 2012
    Absolutely. It's a very common modification.
  • kidglove13
    How would I go about doing it?
  • dorokusai
    Can you solder and use a Dremel with a metal cutting blade? This is not a project for amateurs but not a project that requires an engineering degree. You should source the schematic for that amplifier or pop the top and start getting familiar with the inside.
  • polrbehr
    polrbehr Posts: 2,861
    dorokusai wrote: »
    +1, are you going to install an IEC where the stock power cord went?
    If I can do it, well... you get the idea LOL
    http://www.polkaudio.com/forums/showthread.php?99601-Mods-for-IEC
    It is worth the time and effort too, and will allow you to try a bunch of different PCs.
