Help EXCEL GURU, CONDITIONAL formatting
doggie750
Hello Polks,
Kinda need help to condition col A,B,C and D on sheet (INPUT). The source will be from sheet (REFERENCE) col A,B and C. The objective is to auto-populate Col A,C and D once I enter Col B data on sheet(Input), capturing what's on col A and col C from sheet(Reference).
For EG: sheet(input)
If I enter 21 on col B, the col A (1805), col (Pipe Bend) will populated. Also Col D will be conditioned if col C = Tap,Elbow, then col D = 'MAJOR' otherwise 'N/A'
I can figure this out but will take me hours
as my excel has been down the drain. Any help can be appreciated. Thank you.
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
Figured it out, problem solved.
Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Odyclub; Xsimulator; Sony; Zune; Canon -
Post the solution, so someone else (me) can piggy back on your solution
will do
) Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
