STA 12B's--convert to banana plugs?
laotzu61
Is there any way to convert my STA 12B's to a banana plug input, rather than non-terminated speaker cable; and would it make an audible difference if i can? thanks.
"The symbol is not the reality"
Ummm. SDA2B or RTA12B? Aren't those a 5 way binding post already?Too much **** to list....
pictures or it is going to be hard to believe
i have some non-terminated cable i ordered from blue jean coming monday or tuesday. i'll take some pics then. because of the way i have my stuff set up, i try not to move any of it around unless i absolutely have to. i'll take some pics of that, too. thanks for the input."The symbol is not the reality"
He may have plugs in the end of the binding post and not realize they can be removed?????? The should be 5 ways on there!Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
